Question about JVC AV-48P775 48" HDTV
THE TV IS CONNECTED TO CABLE BUT THE PICTURE COME OUT STATIC WHAT IS THE PROBLEM
Posted by msalcedo760 on
R Martin
    Problem Solver:
  • 5 Answers
Check your setup instructions for your TV. f you're actually using a cable TV service, your setup would be different than for on-the-air TV. Normally - using your remote - press MENU then SETUP and select Cable TV. I'm assuming your TV isn't an older model TV.
Posted on Aug 18, 2009
I'm not sure what card, I need to replace on my TV to fix it and was hoping you could help.
You are on the right track determining that there is a connection hassle preventing your tuner from working properly. Could be a bad wire connection or a bad solder joint on the board.
Feb 03, 2016 | Televison & Video
Vizio TV has intermittent white noise issues
If the TV is connected to a Set-Top box such as a cable box or Satellite box, try a new box, otherwise it would be a defective main board.
Feb 24, 2018 | Vizio E320i-A0 32 Class LED Smart TV
Tv picking up channels except its all static, colorless, and loud static noise..
If the set was purchased in the USA it has the USA format which is NTSC--unless the signal is NTSC picture will be in black and white and no sound.
If the signal format there is PAL OR SECAM you will need a converter that takes that and outputs NTSC for the set to work properly there.
May 16, 2012 | Panasonic Viera TX-32LX70 32 in. LCD TV
Static in the picture
Light static in picture is usually caused by a bad cable connector.
- things to check/questions:
Does it happen with all sources DVD, VCR ?
Are you on Antenna, Cable, Cable box or Satellite?
Does it happen on all Channels?
Do you use the cable input or audio video inputs?
The problem is usually not serious and is usually external to the TV
Oct 22, 2009 | Mitsubishi WD-52525 52" Rear Projection...
My tv picture jumps when I walk by it. Is it the
It is EMI ... electromagnetic interference...
Do you carry your cellphone when this happens? Maybe your iPod?... could also be static charge on your clothes (not likely, but possible)... like wearing sox on a carpet...
Please comment for further help...
Sep 09, 2009 | Televison & Video
Bad/No reception problem on older tube tv worked good yesterday
have your tuner check for any cold solder on pins.
Jul 29, 2009 | Televison & Video
Picture becomes fuzzy in different areas of the screen
sounds like a splitter problem try replacing splitters
Mar 24, 2009 | LG 50PX5D 50 in. Plasma HDTV
My dvd/vcr player has alot of static and lines on the tv
Check and make sure you have the composite cable (5 color cable) connected correctly and you have the NTSC/PAL set to NTSC (north american if applies) If you have a audio out (r/wh) cable into the RGB inputs on the TV, itll knock out a color or chroma channel and itll look strange.
Nov 15, 2008 | Sanyo DVW-6000 DVD Player/VCR
No sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Oct 19, 2008 | Televison & Video
Open Questions:
See all JVC AV-48P775 48" HDTV Questions
JVC AV-48P775 48" HDTV Logo
129 people viewed this question
Top JVC Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
