Question about Taylor Measuring Tools & Sensors
Need online manual for a Taylor WEC-1502 digital thermometer
Posted by Carolyn Whipple on
5 Related Answers
Anonymous
  • 70 Answers
SOURCE: removing songs off of gl-1502 mp4 digital player
Derrick,
i'm not familiar with this player but i think you can still use this method.
Connect your MP3 player to a PC. then Pc will start looking for a new hardware device. Once it found your new hardware device click "my computer" you will now see the there a new drive in your pc. it's either drive E: or G:
clikc the new drive and you will see subdivided folder indicating "video" "MY PIC" "audio" or in some cases once you open the newly found drive it will automatically shows all your uploaded song and files.
once youv'e seen the files you want to delete you can simply "right click" the mouse and from the drop dialogue box select " delete"
cheers,
mark
Posted on Jan 17, 2009
Anonymous
  • 163 Answers
SOURCE: I bought a Taylor Weekend
You can download the Instructions from Taylor's website: http://www.taylorusa.com/media/IBs/806E_ib.pdf
Posted on Dec 18, 2010
Anonymous
SOURCE: how do you replace the battery on a Taylor 508
1) remove the soft rubbery cover from the back of the thermometer, this will expose a screw which holds the front plate on. 2) remove the newly exposed screw 3) use a knife or screwdriver (in the small slot on the side of the thermometer) to pry the two pieces of plastic case apart. This will expose the battery 4) use a screwdriver to remove the 1 screw holding the battery cover to battery. 5) replace with a CR2032 3V Lithium cell 6) replace screws and covers
abhisheks898
SOURCE: Taylor 1431 Digital Wireless Thermometer
yes there is a solution to stop the beep. Take a piece of cotton and put into ur ears..... simple
Posted on Jul 05, 2011
Coolasaurus
SOURCE: Can't reset Taylor 5367 indoor/outdoor thermom
I changed the batteries on mine and it reset itself. That was easy.
Posted on Aug 19, 2011
How can i stop the taylor 1341 digital thermometer from beeping.
remove four screws on back of unit,cut red wire going to round beeping speaker inside lower front faceplate. problem solved it will never beep again but still read temp correctly.
May 19, 2014 | Taylor 1431 Digital Wireless Thermometer
Installed new batteries, but need instruction to reset temperature readings
Type "Taylor 1524 manual pdf" in google. That should pull up your manual. Sometimes companies produce the same item, with just subtle changes (product differentiation) i.e. Chevy used the same motor block for the 327,350,400 chevy motors, and just installed different cylinder heads.
Apr 22, 2014 | Taylor 1524 Wireless Indooroutdoor...
Taylor 1431 Digital Wireless Thermometer beeps at random intervals. Is there a way to silence it?
Jul 05, 2011 | Taylor 1431 Digital Wireless Thermometer
Current temperature on Taylor TruTemp 3528 reads "LLL"
It needs calibrated. LLL (low) means you need to put the probe in a glass of ice water. It will then say HHH (high) means you need to put the probe in boiling water, don't let the probe touch the sides of the metal pot of boiling water.
May 07, 2011 | Taylor Instruments Taylor TruTemp Digital...
Lost my instructions. I replaced the batteries and I can't get it to sinc up.
go to http://www.taylorusa.com/digital-indoor-outdoor-thermometer-1.html and select the link for the manual (Instruction Book under support info, bottom right)
Jan 29, 2011 | Taylor 1522 Indoor Outdoor Thermometer
How do you check the temp coming out of the unit on this controller
you need a thermometer. like this one...
http://www.amazon.com/Taylor-Digital-Instant-Read-Pocket-Thermometer/dp/B00004XSC3
hold it under the hot water. this is what I use, they work great and pretty accurate.
Sep 06, 2010 | Rinnai Digital Remote Water Heater Control...
Measuring Tools & Sensors Logo
328 people viewed this question
Top Taylor Measuring Tools & Sensors Experts
deton8 von Splosion
Are you a Taylor Measuring Tool and Sensor Expert? Answer questions, earn points and help others
