Question about Cooper Industries Weller Kit, Super Pro Portasol Soldering Tool
What type of solder is the best to usefor the weller pro soldering tool cht100
Posted by tempestviole on
Anonymous
  • 867 Answers
For any gun you use, the more silver in the wire the better, also use a core flux(acid is in the middle of the wire) type. the better stuff is worth the bit of extra cost. it is always worth buying the best wire.
Posted on Aug 17, 2009
Anonymous
  • 491 Answers
It's not the solder you use for the soldering tool but the correct solder for the JOB you are doing with the tool.
Read the packages and pick the right mix/flux/thickness etc for the metal/connectors/etc you are soldering.
Do stained glass soldering tips go bad or stop working. I have a weller soldering iron that doesn't heat up hot enough to solder. is it the tip or the iron
If this is the dual trigger Weller gun and your tips are held in place by either set screws or by locking nuts, Just loosen both of the parts that are holding the tip to the gun and then retighten them back up. Soldering iron tips that appear to be tight might not be and this will insure that the tip is indeed tight and also cleans up the connection of the tip to the soldering iron. Oxidation from heating and cooling will cause a tip to not get very hot. Loosen the tip holder and then retighten it. Hope this gets you going again.
Dennis
Apr 15, 2017 | Weller Welding Tools
Is there good operating instructions, or manual for Weller 8200 N 100/140 watts gun?
There are normally three of the same type. They are consumable, you don't need to stock all the different types - just buy the one you need for your current project.
Note, these are high power and were commonly used for soldering wires in the point-to-point wiring used in old tube electronics. Do not use this on a Printed circuit board - it will damage any silicon component.
Use a a soldering pencil for printed circuit boards.
May 16, 2014 | Weller 8200 Soldering Gun
Need a wire diagram for Weller Pes51 50watt Soldering Pencil
http://ptsunow.wordpress.com/2011/06/13/weller-bp860mp-removing-the-button/ I hope this helps
Dec 30, 2012 | Weller Pes51 50watt Soldering Pencil
Is the weller 8200 comparable to the "Old Weller
Hello, your Weller 8200 soldering gun is rated at 140 or 160/100 watts. While the junior was about 70 watts. Go to this web site for parts: www.e-sonic.com/aboutus/cat/S/soldering%206.pdf GB...stewbison
Apr 23, 2011 | Weller Welding Tools
Weller soldering gun replacement light bulbs
that takes a common 6volt screw in type bulb you can buy at most radio shacks or parts stores
Jan 22, 2010 | Weller 8200 Soldering Gun
NEED MANUAL FOR Weller soldering station WESD51 POWER UNIT
You can download the manual from here: http://www.weller-toolsus.com/MagentoShare/media/mannuals/WES51_OI_PL.pdf
Jan 19, 2010 | Weller WES51 SOLDERING STATION
Soldering iron troubleshooting
Bits: It's useful to have a small selection of manufacturer's bits (soldering iron tips) available with different diameters or shapes, which can be changed depending on the type of work in hand. You'll probably find that you become accustomed to, and work best with, a particular shape of tip. Often, tips are iron-coated to preserve their life, or they may be bright-plated instead. Copper tips are seldom seen these days.
Aug 27, 2008 | Cooper Industries Weller Soldering Iron,...
Cooper Industries Weller Kit, Super Pro Portasol Soldering Tool Logo
136 people viewed this question
Top Cooper Industries Welding Tools Experts
David Soto
David Soto
Bill Boyd
ray gallant
Are you a Cooper Industries Welding Tool Expert? Answer questions, earn points and help others
