Question about Tag Heuer Watches
I have a tag Heuer kirium model cl111a recently purchased but I can't adjust the time on it
Posted by Ian Brassington on
1 Related Answer
gemineye61
Janelle Schoonover
  • 842 Answers
SOURCE: need a replica watch strap for my tag heuer watch
Best place that I have found:
http://www.watchbands.com/category.aspx,,categoryID,,25
Posted on Aug 18, 2010
How do I turn off eol on my tag
"EOL" means "End of Life." The battery needs to be replaced soon. I agree with other post. . . if you had the battery replaced recently, it was bad. I have had my Tag Kirium Formula One for 12 years and have only replaced the battery once.
May 10, 2014 | Tag Heuer Kirium Formula 1 Chronograph...
Cl111A-0 manual
I have it in PDF file
if you still need it let me know
Oct 08, 2011 | Tag Heuer Formula 1 Alram WAC111A.BA0850...
I have a Kirium F1 Chronograph CL111A and it works fine except the upper button has stopped having an audible "click" when you press it, and so , I cannot access some of the functions. What...
My previous Kirium F1 had this problem as well.. got it fixed by my watchmaker for a nominal fee (<USD40). Apparently, the push connector needed to be repaired. After the repair, it was "clicking" again and worked fine. However, the watchmaker did warn against pushing the buttons too hard. This is apparently a common problem for this model.
Apr 10, 2011 | Tag Heuer Kirium Formula 1 Chronograph...
Where do I purchase extra links for my kirium band?
Contact Tag Heur Customer Service at 866-260-0460. They are open 9 AM - 6 PM Eastern Standard Time Monday to Friday
Oct 28, 2010 | Tag Heuer Kirium (CL1212.BA0705)...
My alarm does not sound on my Tag Heuer Kirium F1?
Have you a copy of the manual?
If you have, then you will see that it can be turned off (last page), is this likely to be the case?
If you need a copy, go to their web site "tagheuer.com", select "watches", then "tag heuer formula 1", then "man", followed by "Tag Heuer F1 chronometer" and finally you will see on the right a menu, select "user manual".
This seems to be a generic manual that cover both the chronometer and alarm version of the watch.
If these are not the correct instructions for your watch, opposite the "user manual" menu is a search box, put your watch model in this and there should be a user manual with it.
If not look at a similar watch for a generic manual.
Jan 27, 2010 | Tag Heuer Kirium Formula 1 Chronograph...
What are the two digital displays on the top of the Tag Kirum F! for??
Use this link and read the info:
http://www.google.com/imgres?imgurl=http://image.vialuxe.com/Newsimages/1965_LRG.jpg&imgrefurl=http://www.vialuxe.com/News/Tag-Heuer-Tag-Tag-Heuer-Watches-TAG-Heuer-Kirium-Formula-1-Watch/315,870&h=260&w=315&sz=20&tbnid=mdhtEFEWdkvSlM:&tbnh=97&tbnw=117&prev=/images%3Fq%3Dtag%2Bheuer%2Bkirium%2BF1&usg=__PEFomHqQ5EXL6ulbCMX7La4FbWQ=&ei=pMuBSsytA4KsjAfZ3LmECg&sa=X&oi=image_result&resnum=7&ct=image
All that is one link.
Rate me, please.
Aug 11, 2009 | Tag Heuer Kirium Formula 1 Chronograph...
Watches Logo
125 people viewed this question
Top Tag Heuer Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
