Panasonic Lumix DMC-TZ3 Digital Camera Logo
Posted on Aug 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you delete multiple pictures from the panasonic lumix DMC TZ3.  What mode and or functions on the camera do I use to delete multiple pictures at once?
Lee Hodgson
Level 3:
  • Panasonic Master 4,810 Answers
  • Posted on Aug 17, 2009
Lee Hodgson
Panasonic Master
Level 3:
Answers
4810
Questions
Helped
1782736
Points
15941
The quickest way to multiple delete pictures from you camera after you have copied or backed them up is to use the camera's menu to format the camera or/and card.
Regards.
I have a Panasonic Lumix DMC L580 and it states that the memory is full. As i dont have a manual how do i delete what is held in the memory please cheers
Are you sure of the model number? I can't find anything about a Lumix DMC-L580. There is a Lumix DMC-LS80. Make sure that you save any pictures before deleting them. Also make sure to have fresh batteries or the camera connected to AC power. If the camera runs out of power, the process will not complete.
To delete pictures from the internal memory, slide the recording/playback switch down. (The switch to the upper left of the arrow keys on the back.) This puts the camera in Play Back Mode. Use the Up/Down arrows (if needed) to select normal playback mode and press Menu/Set (in the center of the arrow keys). The delete button is the one on the right side below the arrow keys. Use the left/right buttons to select a single picture. Press delete. Press the left arrow to highlight Yes. Then press Menu/Set to confirm deleting the image. To delete multiple pictures, use the down arrow to get to Multi Delete or All Delete (instead of the left arrow). Press Menu/Set.
For All Delete, you may see an option to choose All Delete or All Delete except (star). The star indicates Favorites. If needed, pick one, press Menu/Set. Use the left arrow to select Yes and press Menu/Set again.
For Multi delete, use the left and right arrows to navigate through the stored pictures. Press the down arrow to select an image to delete. When you have marked all of the pictures that you want to delete, press Delete again. Press the up arrow to select Yes and press Menu/Set to initiate deleting these pictures. (Note: if a picture is protected, pressing the down arrow will result in On icon blinking red.)
The manual for DMC-LS80 is available from Panasonic support here: https://www.panasonic.com/au/support/manual-download/imaging/lumix-cameras/dmc-ls80.html . The current link to the manual is https://www.panasonic.com/content/dam/Panasonic/support_manual/Digital_Still_Camera/English_02-vqt3-vqt9_other/DMC-LS80%20Operating%20Instructions.pdf . See page 20 for the section on selecting the mode. See page 35 for deleting pictures.
I hope this helps.
(if you have a memory card in the camera, you will need to do the delete steps in two steps. Delete all (or multi) pictures from the internal memory and the memory card separately.)
What can I do to access certain items in my Record menu of my Panasonic Lumix DMC F300?
Some of these functions are not available when other options are set on the camera. HDR and handheld night mode aren't available if you are saving the images with the Quality set to RAW or either RAW + JPEG option. It doesn't work with still pictures when in movie mode. HDR is also not compatible with the Time Lapse Shot or Auto Shoot in Stop-Motion Mode. I'm not sure if there are similar limits with the Panoramic shot mode.
See the advanced manuals available on the Panasonic Lumix DMC-FZ300 product page, http://shop.panasonic.com/cameras-and-camcorders/cameras/lumix-point-and-shoot-cameras/DMC-FZ300K.html , for these restrictions. The direct link to the manual is currently ftp://ftp.panasonic.com/camera/om/dmc-fz300_en_adv_om.pdf . Page 78 covers the Handheld Night Shot and page 126 covers the HDR mode. Look in the box with the blue background for these limits.
I hope this helps.
How do I delete pictures on my panasonic lumix dmc-FX10
Bring up the picture you want to delete and press the button with the garbage can icon...follow the on-screen instructions.
12helpful
Panasonic Lumix DMC-TZ4 black - memory card locked
Remove the SD card and slide the lock switch on it to the unlocked position. If it's already there then slide it fully to locked and then fully back again.
If this fails then you need to try another SD card to see whether it's a camera fault. If the camera is at fault then there's nothing more you can do other than to return the camera to Panasonic for repair.
1helpful
Delete pictures computer
Never on computer. If you've downloaded the pics, format the card in the camera.
1helpful
Multiple copies of pictures
Yes may be, there was a same query here;
Check the settings for "Burst Mode" in your Cam, it will be under main settings menu. Turn it off, if the problem prevails better backup all the pics/videos and then Reset the Camera.
If helpfull, kindly do Rank.
Regards,
Waqar
How do i take multiple photos with my dmc-tz3 camera
You can't do it in the "simple" mode. But if you pick a scene, you can turn on the "Burst" function.
1)push menu/set button
2)arrow down to second tab (picture of camera)
3)arrow right to allow you to scroll down list to burst function and change to "on"
How do I delete a picture on the Panasonic LUMIX DMC-LC40
When reviewing the images on the LCD with the image you want to delete showing on the screen you push the button that has a trash can icon. The camera will ask you if you want to delete the file yes/no; scroll to yes and use the right arrow button to confirm.
CLEAR PICTURES OFF DISC
Select a picture (pres rev button)
Then press the Del button twice.
The display gives you the option to delete all the pictures or multiple pictures.
Hank
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
