Question about Creative Labs ZEN Vision:M Digital Media Player
Suddenly my creative zen vision m 30GB turned off and will not power back on. It will not enter recovery mode or respond to being plugged in. any ideas of whats wrong, and is there a way i can fix it?
Posted by gstringbass on
Anonymous
    Problem Solver:
  • 8 Answers
Have you tried to plug into AC yet? once mine simply refused to turn back on after a nice freeze, the reset hole did not work, and Pc did not recognised the player. It only entered recovery mode (automatically) when I used the AC charger as a last resort. if the recovery screen comes up, select reboot...
Posted on Aug 19, 2009
Creative Zen Vision M 30GB wont turn on
Problem could be the combination of a bug that causes the device to freeze and the battery running out. If...
- the player won't turn on
- the player won't connect to PC
- the standard reset action won't work,
plugging the player in the AC charger may pull up the recovery screen which will allow you to proceed and reboot, provided the player has no other eg hardware issues.
Aug 19, 2009 | Creative Labs ZEN Vision:M Digital Media...
Rebuilds Randomly
Do the following on the Vision:M and run a cleanup. First, enter into rescue mode by detaching the Zen Vision:M player from your PC , and making sure that the unit is off.
Then, Slide the power switch towards the power icon and hold the switch in the Power On position.
Next, Push the end of a straightened paper clip into the reset hole,and press gently and remove.
The recovery mode will come up, I would choose clean up, this will not erase anything.
Also, I make sure the player is off before you shake it, as you can damage the hard drive inside if it is on when you shake it.
Mar 17, 2009 | Creative Labs ZEN Vision:M Digital Media...
My creative zen vision:M 30GB
Hi you can try going to Creative's web site and downloading there Creative MP3 Player Recovery Tool software and what that does is update everything and most of the time it will fix what the problem . I would try that first.
I hope this helps
Jan 05, 2009 | Creative Labs ZEN Vision:M Digital Media...
Creative zen m vision won't start up,
You tried these yet?
Reset, Format or Clean Up a Zen Vision:M
If your player stops responding, you can reset it. To reset the player, push the end of a pin-like object (for example, a pin or straightened paperclip) into the Reset hole. This should not cause you to lose any data or audio tracks, unless you were in the middle of transferring an audio track.
To reset Zen Vision:M to factory default settings:
Press on the Menu/Back button on your player, and select System, and then Reset.
To Format or Clean Up Zen Vision:M
1. Detach the Zen Vision:M player from your PC , and ensure that the unit is off.
If the battery is too low, charge the battery fully before continuing
2. Slide the Power switch towards the Power icon and hold the switch in the Power On position.
3. Push the end of a pin-like object (for example, a straightened paper clip) into the reset hole, press gently and remove.
4. Release the Power switch when the Creative logo appears. The Recovery Mode appears:
* Clean Up (Performs a disk scan on the player's hard disk, it will not affect music files)
* Format All (Formats the players hard disk - Note: all contents will be lost)
* Reload Firmware (Reloads the Operating System on the Zen. Select this option ONLY if there is a firmware available to reload.)
* Reboot (Reboots the device).
5. Select Clean Up or Format from the Recovery Mode, and then select Reboot.
http://dmzweb4.europe.creative.com/...com:80,Case=obj(14048),Kb=ww_english_add
pls rate it, thanks
Nov 12, 2008 | Creative Labs ZEN Vision:M Digital Media...
Stuck in recovery mode--would love to avoid buying a new mp3
I had the same problem as your and it stopped working yesterday. After search for helps and now it is working again after I reloaded the firmware. But unfortunately everything is gone. You have to reload your musics again. You can try this out: 1) go to creative labs website to download the "Recovery Tool". 2) at Recovery Mode of your zen there are options: Clean Up, Format All, Reload Firmware, and Reboot. Try out Clean Up first if it still not working then try to Format All. After that try the Reload Firmware. After you done the Reload Firmware. 3) Shut down your Zen and try to connect it to your computer. Now your Zen will automaticlly power On and computer will recognize it as a drive. 4) Open the Recovery Tool you have downloaded at creative labs website. This tool will detect your Zen and follow it's instructions: It works with my windows Vista. Well, it works for me, I think it will work for your too. Good Luck!
May God bless.
Jul 15, 2008 | Creative Labs ZEN Vision:M Digital Media...
Buttons won't work
Reset - do the four things in svc mode
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
May 21, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Non responding mp3 zen vision
when you say you upgraded the firmware you have downloaded the firmware from creatives site?
if it was me i would take it apart and see if dirt or something is loose or not fully connected.
good luck
please mark the post with a fixya
Feb 07, 2008 | Creative Labs ZEN Vision:M Digital Media...
CREATIVE ZEN VISION MZEN VISION M TECHNICAL SUPPORT
read this:
http://www.anythingbutipod.com/forum/showthread.php?t=10960
Dec 12, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs 30GB Zen Vision:M
To put songs on your creative, just use the software that came on the cd. If you don
Jul 18, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs ZEN Vision:M Digital Media Player Logo
Top Creative Labs Audio Players & Recorders Experts
aliasger yq
Jean Sintulaire
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
