What is the control layout on Alleycats? Is it 2 volume 1 tone? What is the control on the lower horn of the guitar A tone filter? Once I have this info then I can figure out how your guitar is wired.What is the control layout on Alleycats? Is it 2 volume 1 tone? What is the control on the lower horn of the guitar A tone filter? Once I have this info then I can figure out how your guitar is wired.
You can't post conmments that contain an email address.
Ray's answer is correct.
If you pry the plastic knob straight up off of the tone pot shaft, you should see the retaining nut.
I would usually take the time to open up the plastic cover on the back of the gutar first, to make sure that the wires haven't been twisted around too badly, since the pot has been moving around, to align it to the proper position before re-tightening the nut.
Most likely it is wired like most Gibsons. The volume knobs are the two at the neck end, the tones are the two nearest the rear. The lower two are volume and tone for the bridge pickup, the upper two are for neck pickup. Switch down is bridge or lead pickup, switch up is for neck or rythym pickup, and centre position is both pickups one, where all knobs can be used together.
Try here:http://www.google.com/imgres?imgurl=http://www.electric-guitar-info.com/images/Epi-wiring-circuit1.jpg&imgrefurl=http://www.electric-guitar-info.com/les-paul-wiring.html&h=348&w=503&sz=48&tbnid=aSO6CWOP8JpBPM:&tbnh=90&tbnw=130&prev=/images%3Fq%3DEpiphone%2BLes%2BPaul%2BSpecial%2Bwiring%2Bdiagram&usg=__tWQm6BV6hWlRkesXsvExeuCGPcI=&sa=X&ei=emZjTP3YCsH38AaV7q2vCQ&ved=0CBgQ9QEwAQ or here:http://www.guitarpartsshop.co.uk/acatalog/electric-and-bass-guitar-circuit-diagrams.html
The controls should be setup in pairs (as long as the electronics haven't been modified. The two closest to the pickups are the volumes and the other two are the tone controls. The top knob set should be your neck pickup and the bottom set is for the bridge.
Schematics and wiring diagram for the typical les paul (sheraton) controls: http://www.guitarelectronics.com/product/WDUHH3T2202
