Question about Amana SXD524VW Side by Side Refrigerator
Amana model SXD25QA3W. Not cooling. Compressor runs.
Amana model SXD25QA3W. Was working OK but water formed on floor below freezer door. Ice in bucket looked melted. Found water supply line in freezer frozen. Defrosted with hair dryer. Now, it doesn't blow any cold air in freezer section. Refrigerator is just cool. Compressor and rear fan run.
Posted by baniak_g on
Anonymous
    New Friend:
Low on refrigerant which is R 12. EPA has stopped the manufacture of it and it is priced out of sight.
You have a leak and will need it fixed. Compressor is about $300-400 list. You don't want to go there.
Good luck but likely 15-17 years old....... New one ???
Posted on Feb 21, 2011
Ice maker stopped working on bottom freezer amana. Is there a reset button?
There is n such reset button,but first check and confirm that water line is running in to the ice maker drawer.Is the water getting into icemaker or not.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Amana ARB2214C Bottom Freezer Refrigerator
Kenmore model 106.72009010 leaking water onto floor
Defrost is not working and that is causing the leak.
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
The freezer rale broke
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 22, 2012 | Amana ABB1927DE Bottom Freezer...
Ice Dispenser on Kitchen Aid Model KSCS25FTBL has stopped working
It can be faulty ice maker assembly and needs to be replaced.
Sometimes it visually sees ok,but actually its worn out or cracked causing the problem.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Amana refrigerator freezer is warm
The problem can be temperature not set properly or any of fridge or freezer door not closed properly and cool air is getting leaked out. These are basic possibilities which first need to be checked. But if these possibilities are checked ok and still the problem is same, then its weak compressor issue. Click the link below for more details:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
This will help. Thanks.Helpmech.
Nov 01, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Have an Amana fridge, 22.6 cu ft, 12 years old, side-by-side, water/ice on door. Freezer quit working over a 3 day period. All the food thawed. Not sure if the fridge part is getting warmer also -- not...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 20, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker leaks or runs over Causing big chunks of ice in the drawer
It's very possible that the water inlet valve isn't cutting off completely. I had that to happen on mine.
Mar 17, 2010 | Amana ATB1832AR Top Freezer Refrigerator
Our freezer is not cold, food is defrosting, ice is melting. Refrigerator is working, freezer is not. We hear compressor running continuously. This is a side by side Amana model with water & ice maker...
Look at the back of the freezer wall from inside the freezer. Is there frost on it? If there is, you need to replace one of the components of the defrost system. If there is no frost then you need to have a repair made to the sealed system, it is either out of gas or the compressor is running inefficiently
Jun 20, 2009 | Amana 22.6 cu. ft. Side-By-Side...
My fridge is not cold though the compressor is running.
If any fans stop cooling stops. The fan inside the freezer will need to be examined for why it stopped or if the one below is stopped it to will need to be checked. I think your defrost timer is on the front of your refrigerator on floor behind the kick plate. If you can turn the timer clockwise until refrigerator starts or stops that may tell us the reason for these failures. Place your model in the model search feature below and choose one of many the same models. Look inside back of freezer wall after you unplug refrigerator and tell me if fan is stopped and if coils have ice or snow covering them.Then we will go from there.Click link below. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
May 24, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Neither Freezer nor refrig is cooling
Pull the compressor side cover off. Pry off the square box. This is your compressor start relay. Check for continuity. It's probably blown. If ok check for voltage to the compressor.
Jun 07, 2007 | Amana ASD 2624 Side by Side Refrigerator
Amana SXD524VW Side by Side Refrigerator Logo
Top Amana Refrigerators Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
