My Marantz SR-18EX Receiver loses it's settings when I lose power, or if I turn the power off. It retains them in standby, but not when I turn the big power button off on the front of the receiver. I realize that this is probably a capacitor or battery problem.. Does anyone know if this is an easy fix for a DIY. I have moderate soldering skills.
Also, my center channel seems to occasionally distort and get a bit muffled, then it comes back fine. This is a newer problem... wondering if this is something easy to fix?
Any help would be GREAT!!!
There is a 1 Farad "super capacitor" that needs to be replaced. You need soldering skills to do it. The board is accessible if you remove the front panel of the receiver. The part # is DB-5R5D105; you can get them on eBay for about $2.00 each. Regarding the center channel issue, you may have a bad solder joint on the P781 connector on the P774 board. This is the board that houses the output transistors for the 3-channel main amp board (P704). If not these solder joints, you have a weak driver transistor on P704, and troubleshooting would probably be best left to a pro. Good luck!
Take the case off (Carefully of course) and look for the watch battery, replace it, and unless something is gone in the memory itself, enjoy!
Thanks! And the distortion? How can I troubleshoot this?
There is no watch battery.. near the power supply there are two square modules labeled 24MB with a voltage indication. Also, any thoughts on the center channel distortion?
