Question about Car Audio & Video
Dishwasher not working
Power is connected, the wire is connected
Posted by KC Varma on
While running a cleaning program it turned off and won't power up
You may have a loose power wire down in the electrical box on the dishwasher. Sometimes the wire nuts come loose if they are not securely fully. A loose wire may give it enough power to light the control panel and when the water valve turns ON the amperage increases, then the wires will push apart. This is because the two loose wires become magnetically similar poles and push apart. I have fixed many dishwashers by turning OFF the power to the dishwasher. Removing the lower kick panel opening up the electrical box, then removing the wire nuts, then reattach the wires together with the wire nuts again. Turn ON the power and see if the washer now works. If it does, then reassemble the dishwasher.
If this does not work, then you may have a loose wire connection in the control panel.
Sep 09, 2015 | Dishwashers
MY BOSCH DISHWASHER DOES NOT TURN ON. IT HAS POWER GOING TO IT. I WOULD LIKE TO SEE A WIRING DIAGRAM.?
If you are certain there is 120 volt power connected at the terminals (loose connections do happen), then check the door switch and control. If those parts are working (and it has power) then at least an indicator light would glow. The most likely problem is a loose connection at the power connections where the house wiring connects to the dishwasher. Many instances of this failure have been found. You can also try disconnecting the existing power and connecting to another power source (a heavy extension cord) to see if that makes a difference.
Sep 11, 2014 | Bosch SHX46L15UC Dishwasher
Dishwasher does not run at all,i checked the door
Hello there:
Please try these things i have posted
It doesn't work at all If your dishwasher doesn't work at all, check these: Power from the house Door switch Wiring Timer or selector switch Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker. Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it. Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors. Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be
Jul 14, 2010 | Amana Dishwashers
My Whirpool Quiet Partner III has no power. I
Hello there: It doesn't work at all If your dishwasher doesn't work at all, check these: Door switch Wiring Timer or selector switch Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker. Door switch
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors. Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
May 16, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
We have a GE profile dishwasher. It worked fine last night. Tonight we loaded it and closed the door. Its like it dosent power up.
Oct 11, 2009 | Dishwashers
It's not getting any power to it, but the outlets are working.
most dish washers do not come prewired for power connection. customer or installer provides "pigtail" the part you plug in. Unplug unit, remove kick panel,, follow pigtail to connection bod and remove cover. cut off wire nuts, restrip wires and install new wire nuts
Aug 26, 2009 | Maytag 24 in. MDBH950AWS Built-in...
Dishwasher is not working. No power. I checked the electric box and everything is fine. Pulled dishwasher out, and it seems to be plugged in.
Door switch
Wiring
Jul 31, 2009 | Dishwashers
Dishwasher has no power - breaker in box is on.
Door switch
Wiring
Jul 05, 2009 | Dishwashers
Dishwasher won't start
Door switch
Wiring
May 30, 2009 | GE Nautilus 24" Built-in Dishwasher
Car Audio & Video Logo
111 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
