Question about Karcher 2500 PSI Pressure Washer
Karcher G 3000 BH Engine Pumping Problem
I have a Karcher G 3000 BH pressure washer with the Honda GC190 6.0 HP engine. The engine starts and idols fine, but when using the pressure washer, the engine seems to surge. It will surge between working fine with high pressure to low idle and low pressure. Any ideas where to start?
Posted by ckgregoire on
  • 1 more comment
  • Anonymous Mar 13, 2014
    Karcher
  • Anonymous Mar 14, 2014
    Low water pressure no Matter which tip is used engine is fine
  • Anonymous Mar 17, 2014
    Karcher 3575 low pressure
Anonymous
  • 174 Answers
This may not be a motor problem. It sounds like your pump is not working properly and the motor is just following the pump. First thing to do is check for leaks in the pump, wand hose, gun etc. It may also be a blown water seal inside the pump.
Posted on Aug 18, 2009
Why is the oil in my honda gc 190 grey
grey oil is water contamination. check for leaking seals to stop water getting to the oil
May 21, 2015 | Karcher 3000 PSI Gas Pressure Washer with...
Honda engine will not start,,,new plug, new gas, new oil
Karcher Model G2650 OH with Honda 6.0 HP, GC 190 Engine. Engine won't start. New gas, has spark. Seems to flood instantly. Much gas in cylinder. Spark plug wet. Choke pulled out, power on. Oil OK. released pressure in line. Where can I down load a Honda Engine manual! Thank you !
Jul 06, 2010 | Karcher 2500 PSI Pressure Washer
I have a 3000 psi karcher pressure washer with honda engine, the problem is for a while the pressure would kick in and out, now only water hose pressure, the water supply is fine, what is the problem
sounds like you need a seal and bladder rebuild < if you liver in a cold environmet for winters please dont forget to winterize your washres every year before winter
Sep 15, 2009 | Karcher G3025OH Pressure Washer
I have a Karcher 3000 model G3060 OH WITH hONDA G190
It may be due to some water getting into the engine. I would change the gas and change the oil.
Sep 10, 2009 | Karcher G3025OH Pressure Washer
New Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
Aug 31, 2009 | Karcher 2500 PSI Pressure Washer
Honda GC190 engine shuts down on my Karcher 3000 PSI PW
Well would you believe that I have the very same problem. I suspected that the pump was seizing up, so we tried the pump on another unit and it worked fine. On inspection of the motor we found the cam (which also operates the decompression mechanism) was worn out. It's made of hard plastic. It is only about 7 dollars too, so cheap enough to fix. I have mine ordered now and feel pretty confident that that should fix it.
Aug 13, 2009 | Karcher 2500 PSI Pressure Washer
Engine keeps shutting down
Most Honda engines have an oil pressure switch that prevents engine damage due to low/no oil pressure. Make sure there is sufficient oil in the engine and that the wire is connected to the pressure switch.
May 28, 2009 | Karcher 2500 PSI Pressure Washer
Pressure surge on and off for 2 seconds w/ new Karcher
It can be one of three conditions,
  1. The water supply in is not sufficient
  2. The pump oil is low
  3. The seals are bad in the pump.
I would check the first one first as this is the most common problem.
The water supply hose should be a high volume hose of at least 1/2 inch but 5/8 inch or greater is best.
May 08, 2009 | Honda Karcher G2400HH-R Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
1,161 people viewed this question
Top Karcher Garden Experts
Martin Grech
John Trevino
JOHN LAPIER
Are you a Karcher Garden Expert? Answer questions, earn points and help others
