I have the same problem. It happened after a rug got caught in the tumbler and (I think) caused it to overheat. Is there a breaker that can be reset? How can I locate it? Otherwise, how can I locate the fuse or heating element so I can check them. Thanks!
First check breaker in your main house panel,if good then unplug unit and remove front cover and that will let you access fasteners for top cover remove these covers and you can then access the heating element to chk this for continuity,also chk the hi-limit switch on element case,and if its electronically controlled i.e.has a control panel it could have a fuse on or near the board to protect the electronics...
