Question about Canon NP 6050 Copier
Canon IR3300 dark print out
Help pls.. the Canon IR 3300 i bought wouldn't work out just fine. i refilled the toner, however, its print out became stripes like zebra. please help me...
Posted by seksi_aguina on
Anonymous
    Sniper:
  • 89 Answers
You refilled the toner. Don't recommend refilling the toner. If you're going to spend the money on a copier. You should get genuine toner.
I suggest you make a service call and use genuine toner in future.
Posted on Aug 17, 2009
How to solve canon ir 3300 error code e0000190000
Neele, Error code E000019-0000 is a waste toner full , to get rid of this error, remove the waste toner bottle located left rear side of the machine,dispose of waste toner and clean the neck of the bottle because waste toner could obstruct the toner sensor beam. Switch off then on, OK to use.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Thread Canon IR 2200 Error E000019 0000
Canon ERROR 19 Waste Toner Tank
Jun 13, 2014 | Canon (6981A002AA) for imagerunner 2200,...
I have ir 3300 , when i doing copy bt the platten or feeder , bottom print fadded 2 inch fadded , what is the problem , pls guide me
It may be because of dirty laser unit or the iptics.try cleaning the optics and then the fuser.charging can also be a problem .check DP unit for toner layer .
Mar 11, 2014 | Canon imageRUNNER 3300 All-In-One Laser...
Canon ir 3300
Try the following:
1) check for toner levels (may need new cartridge)
2) check for paper on the tray
3) try printing a copy from that device.
Dec 30, 2013 | Office Equipment & Supplies
Canon ir 3300 error code display e000019-0000
It means that your waste toner box is full.
You can do the next:
On left side of copier, on lower left side you have small cover with screw.With screw driver unscrew it and remove cover. Remowe the waste toner box/container, and clean it, after you removed toner wash it with water and clean the inside and outside of box neck with alcohol to remove the antistatics. Place it back and restart the copier.
Mar 31, 2010 | Canon (6981A002AA) for imagerunner 2200,...
CANON IR 3300 HAS ERROR CODE: E000002-0000
OK, but first try to clear the error under service mode, then replace fixing film assy, for EU 240V is FG6-6041.
To clear the error:
* 2 8 *
COPIER
FUNCTION
CLEAR
ERR
OK
Turn off and on ( main switch )
If this dont help - replace fixing film assy.
Dec 02, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Pls. help..Canon IR 3300 has some problem in printing. Its print out are stripes like zebra. 2inches light, 2 inches dark, 2 inches light and and another inch dark.. solution pls.
Usually this is a drum issue, where the drum cleaning blade is bent in the wrong direction. It would help to know the last time this was changed. They only yield 60K.
Aug 17, 2009 | Office Equipment & Supplies
Solution ?  ,mon erreur E000019-0000
j'ai un problème avec ma IR 3300 il affiche un code E 248-002, que faire? aide moi SVP!!
May 05, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Canon NP 6050 Copier Logo
534 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
