Master
- Posted on Aug 17, 2009
Re: The picture on the tv goes off and on but the sound...
The lamp already need replacement.To replace your lamp you need:
- OEM RCA DLP lamp
- flat-head screwdriver
- T-10 & T-15 torx driver
- pliers.
Steps: Use a pair of latex gloves.
- Locate the lamp through the rectangular at the back of your TV.
- Loosen the screw with your flat-head screwdriver.
- Use the two "clips" to open the compartment door.
- Loosen the screw on each side of the lamp enclosure.
- Gently pull back the tray to remove the lamp.
- Visually inspect the area labeled “Clip.” They are on the top and bottom of the enclosure. Between them, there is about a 3′ gap where you need to push in with your thumb to be able to pull out the rear lamp cover.
- Unscrew the lamp connectors with your pliers and torx driver and remove the three screws.
- Replace the old lamp with the new one. Be sure to put the washer back and all other parts properly.
- Reinstall in reverse order.
