Motorola Mobility RAZR V3 Logo
Question about Motorola Mobility RAZR V3
Motorola RAZR V3M phone won't recharge
My RAZR V3M cell phone now won't recharge. It is only 15 months old. When I plug in the battery charger, there is no "recharging" message and the interface screen doesn't present any flash/ message.
Do I replace the phone or contact Sprint?
Seth Davidson
Posted by sethnteri on
  • Anonymous May 11, 2010
    Clean battery contacts,try another battery,if charge ok and then test 24 hours live time,if ok that battery faulty.if not phone faulty power amplifier, replace PA ic or replace phone, good luck mate.
Anonymous
    Sniper:
  • 91 Answers
First check the charger it must be faulty or if the charger is fine then u need to replace the charging connector
Posted on Aug 17, 2009
Mother board to be replaced in razr v3m
they rae not expensive.. contact www.phoenixtec.ca..they have them for about 10 or 15 dollars
Razr V3M and get invalid charger. I am using the same charger that came with the phone though it is a new battery.
The problem sounds like your phone problem. How old are both the phoen and charger. Who is your carrier. Depending on the carrier you may be able to get the phone replace. If you have are ready purchase a new battery and it is still saying invalid charger more and likely it is the phone. Clean the battery connections with a toothbrush. Also Use can air to blow out the dirt in the charging port. Clean these areas out very well and you should be find. If not contact motorola and have them send you a replacement. If your still getting a invaild charger. You may even be able to get them to send you a charger.
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
My inbox on my razor phone says no messages but memory full
I mentioned this in another area. We just got my son a motorola razr v3m, verizon. Any time he tried to check his inbox (which is text) or tried to send a text it would show memory full....this was the same if he tried to take a picture and send it.
First take out your battery, with the battery out, hold down you on button for like 15 seconds to drain the phone of juice, then put your battery back in it and turn it on. If this did not reset your phone, and if you are on verizon as your carrier, then you need to call them and make sure that they have you set up on their text messaging program. It used to be that if you didn't have, then they would charge you .20 cents a text, but with some of the razr, such as the v3m, you have to actually be on a monthly text plan to view inbox, send text, send pics, and receive pics and texts.
3helpful
Motorola V3m: keyboard lights up:keys frozen,no power to screen.
If you did not replace the firmware,or try and hack the phone then it just died. Nothing last forever. This just means that the light did not die, but the hardware that holds the firmware could have went bad.
You could contact moto and see if they will fix it cheaper than you
can get one off e-bay. You only have 8mo left till your contract runs out. Do not use the upgrade through the carrier,or you are getting robbed. Either wait till it runs out and start a new one or go to
www.wirefly.com, you can get the same exact contract through the same carrier but get a way lower price on the phone,unless the phone you want is free. You could have someone try and reflash
a new firmware on the phone, but I don't think that is the problem.
Hope moto does something for you.
Phone Wont Turn Back On.
put the battery in and press the on (red button),* and # at the same time. wait for the "bootloader usb" message. press the red button again
It Doesnt Turn On Or Do Anything.
Sometimes new phones need a full 24 hours of charging. Have you charged it overnight?
Motorola razr v3m battery problems and bootloader ini showing on screen
Well it is both. It should only ever say bootloader when it is plugged in to a PST machine and getting the software updated. I would say that it the hardware is causing the poor battery life or a combo of the battery and the phone.
Motorazr V3m gets hot and loses charge
there could be a problem with your hard drive on your phone, or the intercooler in it that has stopped running, there is nothing that you can do about it other than take it back to verizon
Top Motorola Mobility Cell Phones Experts
L Vincent Testa
L Vincent Testa
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
