Question about Panasonic Lumix DMC-FZ10 Digital Camera
Problem with my lumix fz10 autofocus. Press the
Problem with my lumix fz10 autofocus. Press the shutter, then the viewfinder goes into focus and then out again. Then after ages - focuses again and promptly works the shutter. Thanks for any help.
Posted by halfcentury on
Anonymous
    Brigadier General:
  • 4,090 Answers
Just make sure you dont have dirt on the lens itself!
or that you have MACRO function set
Posted on Aug 17, 2009
My E 620 shutter does not work when using viewfinder, but works when using screen
While using the viewfinder, does any warning come in the viewfinder?
Not sure, but if you are shooting in a different mode, it could be there is not enough light, or the camera can't focus.
Using the viewfinder the camera will use a different way to focus as when using the display.
Perhaps the autofocus, does not work correct. Looking through he viewfinder, wait till the AF confirmation mark lights up. (bottom left)
If it won't light up, something is wrong with the AF.
Feb 22, 2014 | Olympus EVOLT E-620 Digital Camera
Nikon d5100 Blurry photos When I take photos of a party, at night, my photos are very blurry. How can I fix..
Use autofocus if you have a AF lens on it.
Usually you get a kit 18-55 AF lens that has a A/M switch on the side. The switch should be facing the A side so it's set on autofocus. Then you have 9 points on your viewfinder, those are the autofocus points. It should usually be set to center, because you usually want the object in center of your photo to not be blurry.
Remember to press the shutter button halfway and give some time for the autofocus to focus. Then you can press it all the way, you should have your photos nice and clear.
If you happen to have a manual focus lens, you should be watching through the viewfinder and turning the focus ring on the lens and determine if your object is in focus. It's hard at night, but get some practice at home when you have some more light so you get more familiar with the focus.
Dec 26, 2012 | Nikon D5100 Digital Camera
Nikon D60 does not work in autofocus
Do you have access to another camera? If you do, try the lens on that camera. If you get the same results, it's the lens. If no, then it's the camera body. Once you isolate the problem you'll know if you need to get the lens fixed or if you need to get the camera fixed.
Sep 08, 2017 | Nikon Normal AF Nikkor 50mm f/1.8D...
Panasonic lumix DMC-FZ10 at least 5 years old no longer focuses
There is a switch AF/MF to set the unit to auto focus/manual focus, try to set to AF mode.
Here is the link of the manual
http://service.us.panasonic.com/OPERMANPDF/DMCFZ10.PDF
check page 65
Apr 03, 2009 | Panasonic Lumix DMC-FZ10 Digital Camera
Lumix DMC- FZ30 - screen is black when camera is turned on
Check if you have activated the Electronic Viewfinder (EVF). Press the EVF/LCD button to switch to the LCD screen. If this fails to solve the problem, change the mode dial to Auto (the red camera icon) or 'P' and try again. If even this does not work, check with the nearest authorized service center.
Feb 06, 2009 | Panasonic Lumix DMC-FZ10 Digital Camera
Canon Rbl XT out of focus in viewfndr when shutter half way down
It's possible that the reason the "pictures turn out fairly good" is that your f-stop is set high enough that even though the image isn't properly focused, you have enough depth-of-field to bring your subject into "near focus". Does your lens try to focus back and forth when you half-press the shutter? If not, double check that the lens is in autofocus and not manual focus. You can also try cleaning the contacts between the lens and camera. Take the lens off, and then one-at-a-time clean the contacts on both the lens and the camera, using a clean pencil eraser. Gently rub the contacts. Be sure to hold the item upside down so that the eraser debris falls on to the table, not into the camera body or lens!
If none of this helps the autofocus may have become damaged and you need to have the lens and camera looked at by Canon Repair.
Jan 10, 2009 | Canon Digital Rebel XT / EOS 350D Digital...
Fuzzy pictures from my Panasonic DMC-FZ5
Fuzzie picture -meaning out of focus? Check that you have not got 1- macro setting on [setting symbol looks like a tiny plant] or that you have a low light setting which menas it is taking long exposures. Aslso the Auto foxus may not be function as it should - one possibility is that the way you hold the camera covers the 'window' make sure your fingers are aware from any of the front top panel 'windows' When you depress the shutter part way down- does the lens 'motor' to focus Or indeed are you doing part way or are snapping off shot and giving the camera time to focus? Lots of thing for you to check out, before we start getting worried. The difficult ones are if the camera has taken a knock and the lens mount has become dislodged But do all the check first and do consult the manual
Jun 14, 2007 | Panasonic Lumix DMC-FZ5 Digital Camera
Type of setting in the night
Try using the night mode on your FZ10, but use a tripod.
Sep 06, 2005 | Panasonic Lumix DMC-FZ10 Digital Camera
Shutter lag
I don't know what your measurement conditions were, but there's no way the shutter lag after focus is 1/2 second. I don't have a quantitative number at my finger tips, but it surely falls into the "instantaneous" category, as far as I can tell. I've taken plenty of action shots and candids, including shots of flying birds, that will back that up
Panasonic Lumix DMC-FZ10 Digital Camera Logo
Top Panasonic Cameras Experts
ENFORCER
deton8 von Splosion
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
