Question about Palm Treo 700w Smartphone
Phone frozen. Hard reset doesn't do anything
My phone is frozen at the windows mobile screen and hard resetting doesn't do anything i see my documents when i connect to the computer but i can't use the phone.
Posted by joqa9 on
Robert Bivins
    Sergeant:
  • 192 Answers
A hard reset will erase everything on the smart phone. If you still see your data, then you were not successful in performing the hard reset. In that case, what you have done is a soft reset.
Carefully try one of these two methods:
Main method:
1. Pull the battery out. Put the battery back in while holding the RED button down and a reset screen will appear.
2. Push the up button on the five-way to start the reset process.
Alternate process:
1. Similar to the hard-reset of the Treo 650. Remove the battery cover.
2. Press and hold the Red radio button.
3. Use the stylus to depress the reset button next to the battery.
4. Push the up button on the five-way when you get a prompt to "Erase all data".
Posted on Aug 17, 2009
3answers
I can't start my phone and need to doo a complete reset. How can i do it? Thanks Regards
How to hard reset the Sony Ericsson Xperia X8First, try this:
  1. From the main home screen, tap menu
  2. Tap Settings, then Privacy
  3. Tap Factory data reset
  4. Tap Reset phone
  5. Enter your password if required, then tap Erase everything to confirm
If that doesn't work, or if your phone is frozen:
  1. Turn the power off. If your Sony Ericsson Xperia X10 is frozen, pull the battery out and reinsert it
  2. Hold the Left and right buttons located beneath the display
  3. Press and release the Power button
  4. Follow the on-screen instructions to hard reset your Xperia X10
All data including third-party applications will be deleted from the Sony Ericsson Xperia X8. Once the wipe is complete, the phone will reboot to its factory fresh state.
1helpful
2answers
My G1 Android will come on and show T-Mobile G1 then Android will come up but then the screen is blank? What can I do?
the best solution is to hard reset, follow the instructions bellow
1. Turn the G1 off. If it's frozen on, take the battery out and put it back in the unit.
2. Hold the Home and Power keys down at same time for about 25 seconds. You will see a yellow triangle screen with exclamation point in the middle.
Now to wipe the device clean:
3. Press Alt+L.
4. Press Alt+W for a factory reset.
5. Press the Home and Back keys again for about 25 seconds.
The device should then reset again and the hard reset is complete.
Mar 10, 2011 • HTC G1
9helpful
2answers
How to hard reset LG GW520? The phone starts up and come yo frozen screen. Thanks
Type for soft reset *#7780# . For hard reset *#7370# If it as default 1234
1helpful
Cant hard reset samsung code
dun charge it untill battery is fully discharged.then hard reset via Press the Up Navigation Key and the Power button
Green Window Mobile Screen is frozen, phone will not come on.
you need to do a hard reset i have had windows phones for years and this should do the trick only down fall you will lose all your data if you dont have it synced to your pc here is how to do it http://forums.wireless.att.com/cng/board/message?board.id=samsung&thread.id=19689
Aug 07, 2009 • Cell Phones
1helpful
It gets stuck on the windows mobile screen
You have to execute a "hard reset". The exact method depends on the exact type of HTC phone you have. You should Google for "HTC Touch <your exact phone type> hard reset" and follow those instructions.
Looking at the picture you have a HTC Touch P3450, in which case you can instructions at: http://blog.ryjones.org/2008/01/14/htc-touch-hard-reset/
Make sure you follow the instructions properly. When it still doesn't boot up, you can always perform a firmware upgrade/reset, that's almost guaranteed to work, but is complicated and might break your warranty (depending on wether you bought the device yourself or got it as part of a package deal from your provider).
HTC touch HD is completley frozen
If you have all your items saved to your computer with Active Sync, then do a master reset:
HTC Touch hard reset 14 January 2008
  • Power on.
  • Press and hold buttons marked 1.
  • Press and release 2 with stylus.
  • Release buttons marked 1 when menu comes up.
  • Press directly down on center dpad, marked 3.
You can also get tips & tricks from www.htcwiki.com
It has the latest and great updates, software, even known issues if you ever come across this. HTC does recommend that you do a master/hard reset once a quarter to keep it moving smoothly. Also, ensure you don't have a lot of open running programs. Perhaps once a day, clean the cashe and history. Do a soft reset (aka battery pull) once or twice a week. All depends on how hard you play with this lovely PDA device!
1helpful
2answers
HTC Touch is frozen. I tried resetting but it does not work, as well as take out the battery. I do not want to do a hard reset that wipes the hard drive since I have data I need to back up. When i conect...
Is your phone in the frozen state even after removing the battery for two full minutes? If the phone is still frozen you will not be able to do anything with the phone until this is resolved. And the way to do that is to do a hard reset. Unfortunately there may be no other alternative but a hard reset. The new Samsung Instinct has mobile sync which automatically backs up your contacts into your sprint.com account so if this type of thing were to ever happen you would have the comfort of knowing that your address book was still intact.
Aug 19, 2008 • Cell Phones
I have a Dell Axim x50v running with original ppc2003. Then I upgraded it to Windows mobile 2005, and used for couple of months then it crashed! Now the issue is both soft & hard reset stop loading at 80%,...
Same problem. Soft and hard reset can't even stard any advice screen. When the problem started, it was frozen at the dell round simbol, that i just could turn it off by removing battery. Now, its even worse, the screen is off, even after pressing the two and tree buttons at the same time, it doesn't hard reset. What else should i do?
Palm Treo 700w Smartphone Logo
Top Palm Computers & Internet Experts
Ekse
Mandeep  Singh
Mandeep Singh
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
