Question about Canon PIXMA MP610 InkJet Printer
Do pixma Mp610 support duplex printing - Canon PIXMA MP610 InkJet Printer
Posted by ng_zhijiang_ on
Robert Kitaji
    President:
  • 1,335 Answers
The MP610 does support duplex printing.
Duplex Printing
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the docdo pixma Mp610 support duplex printing - duplex2.gifot fit on one page.
do pixma Mp610 support duplex printing - sub.gifsrc="/uploads/images/duplex2.gif" alt="duplex2.gif" class="h_mi" />
To print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
3. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the settido pixma Mp610 support duplex printing - sub.gifect another value from the list.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
Whendo pixma Mp610 support duplex printing - sub.gifecute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Media Type
on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagakido pixma Mp610 support duplex printing - sub.gif is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Stdo pixma Mp610 support duplex printing - sub.gifde appear grayed out and are unavailable.
sub.gifAfter printing thedo pixma Mp610 support duplex printing - refer.gifge, there is an ink drdo pixma Mp610 support duplex printing - sub.gifit time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex pdo pixma Mp610 support duplex printing - sub.gif, check the Duplex Printing check box.
sub.gifIf the Medo pixma Mp610 support duplex printing - sub.gife dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
Posted on Aug 17, 2009
Anonymous
    New Friend:
Duplex printing can be easily solved by first selecting "Print Odd Pages", then refeeding printed pages into printer then selecting "Print Evan Pages".
Posted on Nov 19, 2010
5 Related Answers
Anonymous
SOURCE: printing CDs with Canon Pixma MP610
I want to print onto cds but cannot find any instructions for a canon pixma mp600
Posted on Nov 14, 2008
Rob Aerts
SOURCE: MP610 How do I duplex
I had the same problem, the operative being had!
All I did was change the paper orientation from landscape to portrait and the problem went away!
Hope this helps!
Robbie
Posted on Nov 29, 2008
Anonymous
SOURCE: Canon MP610 Printer When automatic duplex
I haven't found a way to do this using the printer settings.
There is no (apparent) simple solution, but needing tp print a 56 page pdf form the only solution was to load the pdf into Adobe Acrobat and then in the 'document' pull down menu select 'rotate pages', then select '180 degrees' and also 'rotate even pages only'. This then prints OK.
The down side is that you need full Adobe Acrobat rather than just the reader.
I have been unable to rotate pages through 180 degrees in MS Word but it is possible using MS Publisher.
Misterfish
Posted on Feb 11, 2009
Jim Thurston
  • 672 Answers
SOURCE: My Canon Pixma MP610 printer will not print. It
Possible causes: Empty cartridges or new cartridges with cover strip still on the contacts, plugged printhead, wipe with warm water on paper towel to see if all colors are there, also physicallyclean the black cartridge. Try to print. If not working, use the printhead clean and or prime in the printer's maintenance tab.
Posted on Mar 09, 2010
SOURCE: Canon Pixma MP610 will not print black ink. Page
kkdlist.wordpress.com/2010/07/01/14/
Posted on Aug 02, 2010
Canon pixma mp610 cant delete the printing queue or print
This is not the fault of the printer but windows. Open the Control Panel, select Devices & Printers, find your printer, click on it, select Delete Print Queue. Problem is fixed.
Jan 07, 2013 | Canon PIXMA MP610 InkJet Printer
How do I use two-sided function on my PIXMA MP780?
To print "two-sided" (a.k.a. duplex), open your printer's properties before you print, go to tab "page setup" and check "duplex printing".
Hope this helps,
Stephan
Oct 21, 2010 | Canon PIXMA MP780 All-In-One InkJet...
How do you remove/clean/replace print head on pixma mp610 BK nozzle blocked.
Try this :
The gray-colored arm (it's not that small) is to the right of the cyan cartridge. It is the arm or extension of the gray-colored hinged cover. Remove all ink cartridges, lift the gray-colored arm up, and pull the print head out. Clean the print head with a cotton ball soaked with water or rubbing alcohol. Dry and re-install the print head.
Jun 16, 2010 | Canon PIXMA MP610 InkJet Printer
User manual printer mp610 wanted
Canon pixma mp610 is one of the best All-In-One printer which can turn your home in to an office. It has 4,608-nozzle print head and can print 4" x 6" photos with spectacular 9600 x 2400 color dpi resolution which is its maximum resolution. It takes some around 21 seconds for the same. canon pixma mp610 also has a provision for the memory cards. You may preview the images in the 2.5" TFT display.
Apr 08, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Mar 09, 2010 | Office Equipment & Supplies
When connected to Airport Express via USB, it will
Airport Express provides only a print server, not a networked usb hub so it can only print. I'm afraid you'll have to go back to wired for scanning.
Mar 06, 2009 | Canon PIXMA MP610 InkJet Printer
How to print photos from hard drive canon pixma MP610
dl kodak .com software new 7.0 verison works with all printers bring pic u want up auto fix it then print button on top should do it k free software and the best
Oct 06, 2008 | Canon PIXMA MP610 InkJet Printer
MP610 How do I duplex print. I have had every second page print upside down. o I manually turn the page over/
Hope this helps!
Robbie
Jul 17, 2008 | Canon MP610 Photo All-In-One Printer
Printing CDs with Canon Pixma MP610
Jun 11, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP610 InkJet Printer Logo
1,428 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
