Question about Thomson TE1152 Top Load Washer
My washing does a lot of noise when it spins even the detergent dispeanser starts vibrating badly i bought this from one friend it is quite new he had stuck tape in the dispenser so that it will not vibrate and create noise i am wondering how to use and how will i put detergent in front loading.i cant even contact the person fromwhom we bought i had good toploading machine but we went for this since it was new mine is thomson front losading PLEASE HELP
Posted by nassuha on
Anonymous
How to dismantel TX738N bearing
Posted on Sep 11, 2009
alimenshawy
    New Friend:
My washing machine tyre(401T-5 KG-ECO POWER)
It was operated at a very high vibration SINCE I installed it.
when I investigate its back I noticed that it has been teared at four points where are four bolts with plastic nuts fixed
I need your help to over come my problem and running again my machine without its terrible vibration
thanks
Posted on Apr 03, 2011
Anonymous
  • 230 Answers
Hell there: sound like it was off balance when you put load in. make sure you put heavy clothes on both sides so it won't get offbalance blankets you go around in circle until it in the washer just one no more it'll hurt it. try it let me know ty
Posted on Aug 17, 2009
Top loading washer vibrates quite a lot during spin cycle
If the machine is level and the feet are properly touching the pads it may be a fault in one of the suspension components or it could simply be the way the load is sitting in the machine during spin cycle. Towels get heavy when soaked and if the load is not balanced inside it will make the machine vibrate. Have you tried the machine without any clothes in it to rule that out?
Dec 27, 2012 | GE Washing Machines
Starts Banging really ******* spin cycle, then quits... seems like the drum is loose.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 12, 2011 | Frigidaire GLTR1670A Front Load Washer
Near the end of the rinse cycle there was a load noise accompanied with a lot of vibration. I stopped it and took out the wet clothes and fininshed manually. To test i put the machne on spin cycle and...
if the clothes bunch up on one side the tub doesn't spin evenly and goes off balance,the tub will start banging all around,if this happens,open the lid and move the clothes around to even them out so all the wieght isn't on one side,it's a common thing mostly with a few items in the washer but can happen with any size load.if it keeps happening send the brand name and the model number.you should be fine.
Apr 17, 2011 | Washing Machines
The spin cycle won't engage, the laundry tumbles, it starts to speed up and then slows back down to tumbling. I've removed some of the laundry, set it to rinse and spin and it still does the same thing....
Welcome to FixYa.
Based on what you've described, there are a few possible scenarios that will cause this.
1) It could be either the shipping bolts are still in place, shown below
2) the water hoses are backwards ( it's critical for proper operation to make sure hot goes to hot and cold to cold )
3) or even you're using too much detergent (or the wrong type of detergent), you must use "HE" only in these frontload machines
4) the leveling legs/feet aren't secured proper or are uneven...
...otherwise it doesn't spin the items out very well either due to too much vibration sensed to maximize spin.
Make sure the shipping bolts are out first, i.e.
Level properly, i.e.
And use only detergent with this label, but not much is necessary.
**especially if your laundry has been washed in a top load prior to now since the items will likely still contain soap from the old washing...maybe pre-wash all your items before placing them in a actual wash cycle with detergent for the first time**
i.e.
Let me know what you find and I'll try to help you move forward from here.
Regards,
Macmarkus :)
Mar 12, 2011 | LG WM2487H Front Load Washer
We just bought a used Frigidaire front loader bought in 2004 and the washer jumps when in even the lowest spin cycle. We have bought a rug for under the washer and it has not helped. Any ideas???
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
heatman101
Feb 02, 2011 | Washing Machines
We just had a new top-load Maytag Washer delivered. When the man finished installing it, he started a wash cycle and left. When it got to the spin cycle there was a lot of vibration. It doesn't...
NO. Have you checked if he installed an anti vibration pads. This is because the high frequency vibrations caused by the spin cycle can cause annoying noise and very serious long term structural damage to you home.
Jan 12, 2011 | Maytag Bravos MTW6600T Top Load Washer
Vibrates, shakes and moves around and has a lot of noise while spinning. It has been leveled and the floor seems sturdy enough.
heatman101
Sep 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Spining makes noise and machine vibrates a lot
its a simple solution just remove the brown colour clamp at the bottom of the machine with a screw driver
Jun 03, 2009 | Whirlpool Washing Machines
Washing machine
Peace Friend,
ngfam1 At your service!
1-it may be the belt squealing or high pitched nosies telling you it wants to go!
2- It more than likely is the rolling suspension that the drum spins on!I've seen the older models with one of 3 wheels that the drum rolls on is worn and wobbling or screaming or screeching etc.
3- I've seen also a few times that the motors heat shield, a simple piece if tin with two screws or bolts holding it down was "loose" and vibrating causing a loud metal squeal noise all the time or intermittently!!
If I were there hands on I could fix it!
Only a trained laundry tech can make the electronic diagnoses.
Unfortunely, another point to consider!!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
*****PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF*****
Aug 05, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer model 41740042990
Even after leveling my Frigidaire washer on a pedestal, the washer shook the house during ramping up on spin cycle. I found some Shake Away pads at Lowes. They are small pads that just go under each foot of the washer. I'm not sure how they work but THEY DO. The best 30 bucks I ever spent
Sep 16, 2007 | Washing Machines
Thomson TE1152 Top Load Washer Logo
672 people viewed this question
Top Thomson Washing Machines Experts
Marvin
Marvin
Are you a Thomson Washing Machine Expert? Answer questions, earn points and help others
