Question about Pioneer PRO-99 TV
TV will not power on. Never when using the remote, and only once in a hundred attempts by utilizing power controls on front of set. Power goes 'green' and immediately (off) to red. If and when TV does power ON - there is no picture, just audio. Last attempt, for whatever reason, picture returned for an hour or so, then began to 'breakdown' and disappear not to be seen again. Pioneer Elite Projection Monitor Receiver Pro-99.
Posted by steve956 on
Chi Chu
  • Pioneer Master
  • 8,457 Answers
Ur video ic converter board it dead.
Need a new board.
Posted on Aug 17, 2009
How do you program a Dish Network Remote to control a DirecTV receiver?
  • 1 Turn on the electronic device for which you'll be using your remote control. You will have to do this manually by pressing the "On/Off" button on the device.
  • 2 Locate either the "Code Search" or "Setup" button on your remote control. Which one you have will depend on the remote control.
  • 3 Hold that button for anywhere between five and 10 seconds. The light on your remote should then turn on. Depending on your remote, the light will either blink or remain on after you release the button.
  • 4 Press the corresponding button on your remote for your device that you are programming. In other words, if you want to program your remote to your television, you would press the "TV" button.
  • 5 Use the numbers on your remote to enter the three- or four-digit code for that particular device. The codes for your remote control will be found in the manual. Don't worry if you have lost the manual. You can find codes for practically every remote control on the market on the Internet. Visit the website of the manufacturer of the electronic device (TV, DVD player, among others) or log onto the "Universal Remote Control Codes" website. Once you have entered the code using the remote, you should notice that the light on your remote has turned off.
  • 6 Point your remote towards the device and attempt to turn the device off. If you can do so, you have programmed your remote correctly.
Programming Without Remote Control Codes
  • 1 Repeat Steps 1 through 4 found in Section 1.
  • 2 Begin pressing the "Up" channel button found on your remote. You will probably have to do this a few hundred times (or anywhere between five and 10 minutes). Once the channel changes, your remote will be programmed. Turn the device on and off using your remote to finish programming.
  • 3 Use the "Power" button if the channel button did not program your remote control. Again, you will probably have to press the "Power" button a few hundred times. Once the device that you are programming your remote to has turned off, you will know that you have programmed the remote control correctly.
Sep 14, 2011 | Televison & Video
Trying to find out how tostart automatic code seach for tv so I can set the code and use the remote for my old daewoo tv
Try Aim tOn the remote control, press TV once. Press and hold SET until the LED (red light) blinks twice, then release SET. Enter 9 - 9 - 1.
Aim the remote control at the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off (after pressing POWER).
Feb 19, 2011 | One For All URC4220 Remote Control
How do i program tv aND DIRECT TV BOX FROM SCRATCH?
You need to turn on your television set.
  • On your DirecTV remote, press the "TV" button once.
  • Now, press and hold the "Setup" button until the "TV" light goes off.
  • Enter "991" on your remote control, using the numeric keypad. The "TV" light on the remote should blink twice.
  • Aim your remote at the television and slowly alternate between pressing "TV and "Power" on your remote, until the television set turns off. Once it turns off, press "Setup" on your remote control to lock in the code.
  • To search for codes for other devices and program them into your remote, repeat Steps 1 to 5, but use the appropriate key for your device instead of "TV."
  • Feb 04, 2011 | RCA RCR311B Remote Control
    3.4 IR Dish Network remote control codes for a Prima TV/DVD combo. I can't seem to find any codes that work for either.
    I'msorry I did also attempt to locate a Prima remote code within DISH Network's database aswell but unfortunately I was unsuccessful and have found no remote codesfor the TV you have. However, we can still attempt to program the DISH Networkremote to the Prima television without a remote code, this would be done bycompleting a Power scan. If you decide you would like to program the DISHNetwork remote to your TV using the power scan, I have included instructionsbelow to further assist you. Withthe desired equipment on, press and hold the correct Mode button (In this casethe mode button will be "TV") until all the other mode button back lightsilluminate, then release. 1. Pressand release the Power button. 2. Pressthe Up button once a second while pointing the remote at the desired equipment. Note: If the code for the equipment comes up, theequipment will power off. 3. Pressthe POUND (#) button. If the codeentered is valid for the remote, the mode light flashes three times.
    After successfully completing the power scan to program the DISHNetwork remote to your T.V the remote should now control your TV. I hopethis helped! Please feel free to let me know if you have any other questions orneed additional help. -Kirstie DISHNetwork
    Jan 30, 2011 | DISH Network IR Remote Control
    IHAVE REMOTE PX-RC1 ILOSE THE CODE BOOK & TV NAME PRIMA
    Press SET BUTTON and at the same time, the appliance you want to set( TV, VCR,Aux...etc). The LED should stay on.. then press on the SET BUTTON again ... the led will blink fast... then press ( in front of TV, of else).. the POWER BUTTON to see what happens, if nothing happens, then press the +CHANNEL BUTTON once, and press power again. Repeat this until it turn off. Then press the appliance button (VCR,TV,AUX, etc...), this will stop the LED to blink and your appliance will be set.
    Dec 24, 2010 | Universal Remote Control MX-500 LCD Remote...
    I have a sanyo tv and the remote is no longer functional, i dug out my old urc11a universal controller and would like to know what codes i need to set the controller to my tv.
    Try pressing the 'set code' or 'code' button and keep pressing it until the light indicator lights. Press tv and after that you are suppose to enter the 3 or 4 digit code and press enter. However, if you don't know the code, try to repeatedly press the power on button of the remote until you get a response from the tv set. sometimes it would take a hundred times or more before you can get a response. Once you get a response, press enter. I have tried it many times in universal remote controls and it works.
    Oct 03, 2010 | Televison & Video
    Lg42lc7d tv (35 total in sports bar) utilizing 5 Crestron av switchers CNX_PV1D8x3. Remote touch screen to control everything. All is well for last 2 years and now some tv's are not turning on. Have to...
    you have some bad power supply.inside the tv's.you need to try several time to power up tv.that way in not coming up by remote.remote only power tv once.
    Jun 09, 2010 | LG 42LC7D-UB Television
    Need the code for the charter remote for my vizio
    For example, to search for a code for your TV:
    1. Turn on your TV.
    2. On the remote control, press TV once; it blinks once. Then press and hold SET UP until the TV key blinks twice.
    3. Enter 9 9 1. The TV key blinks twice.
    4. Press 1 (the device code digit for your TV). The TV key blinks twice. Aim the remote control at the TV and press POWER once.
    5. Press and release the CH+ key continuously, then stop when the TV turns off.
    NOTE: In the searchmode, the remote control sends IR codes fromits library to the selected device, starting with the most popular code first.
    1. Press POWER. The TVshould turn on, then press SET UP to lock in the code.
    NOTE: If the TV does not turn on during step 6, then slowly press and release CH- to go back through the codes, then press SET UP when the TV turns on.
    Jan 12, 2010 | Vizio VO47L 47 in. LCD TV
    I need a four digit remote code for a panasonic TX-28PS12 standard CRT TV.
    what kind of universal remote control are you trying to program? most universals have a channel search feature, you need to locate the code or set up key, press and hold the key until the light stays lit, release and press the tv key once, then press the power key continuously until the tv goes off, stop pressing power when tv goes off and press the enter key once this will leave tv remote set for your tv operation. Not all universal remote the same procedure so you might want to check the web site for the r/c unit you have. please leave pos feedback if i answered your question satisfactorily.
    Aug 24, 2009 | Panasonic Televison & Video
    Toshiba 35a44 problem
    check the following power supply components
    power transistor of the supply
    zener diodes
    rectifier diodes
    Oct 15, 2008 | Toshiba 35A44 35" TV
    Televison & Video Logo
    Top Pioneer Televison & Video Experts
    Demonic-2011
    Demonic-2011
    Raj Patel
    Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
