I have a glass Ceran Schott cooktop that has been in perfect working order. My daughter spilled her hot chocolate on the cook top. It unfortunately went into the knob control area. The cooktop had to be shut off at the circuit breakers as it was acting strangely with smoking and sizzling. Can you tell me what I can do for this problem? Thank you .
SOURCE: Maytag gemini schott ceran stove top
Sugar spills on a hot surface will 'pit' the glass surface. There is no way to repair. The damage caused to the surface is only cosmetic and will not affect the performance or operation.
SOURCE: I cracked my Schott Ceran Cooktop glass
I located a company that supplies a new top but only to find that the tops are 400.00 anyway. I ended up purchasing a new stove to solve the problem.
SOURCE: My schott ceran class top stove keeps saying F1 on
Here below we have aprocedure to try to see if you can save the ERC.
F1 touch pad / ERC test
This simple test will help determine
whether the ERC (Electronic Range Control or Clock) or the touch pad is
defective when F1 error code is present.
Note: Some models
incorporate the touch pad in to the ERC as a single assembly, in which case this
test is not necessary. Simply replace the ERC (Clock).
Warning: If
you feel in any way uncomfortable performing this test or making this repair,
please contact a qualified appliance repair technician.
1. Disconnect
power to the range (unplug the range power cord or turn the power off to the
range at the circuit breaker). It is very important that the power to the range
has been disconnected, so please double check before continuing.
2. Gain
access inside the control panel.
3. Disconnect the touch pad (also called
keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no
lose wires, or anything else that may cause a short when power is turned back
on. Assemble the control panel back the way it was.
5. Turn the power back
on.
6. Wait for at least one hour to see if the F1 code comes back (usually
accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it
does not, replace the touch pad.
