Question about Kenmore Refrigerators
Fridge feels hot to the touch between the fridge and freezer
The other day the fridge was suddenly not working at all. We vacuumed the coils and turned the settings up (significantly) and it started working again (but not as well as before). Now the unit feels very hot to the touch on the front of the fridge between the fridge and freezer. The fridge is still not as cool as it should be.
Posted by eightinct on
Anonymous
    Problem Solver:
  • 13 Answers
I had similiar issues, I found that running a manual defrost cycle (Diagnostic test of the defroster) was enough to get the air flowing accrost the coils in the back of the freeer
Posted on Aug 17, 2009
Samsung RF25HMEDBSR bottom freezer fridge. Fridge is at right temp.,ice maker works, but the bottom freezer is not working.
The condenser coils are usually located under the refrigerator. They dissipate heat as refrigerant passes through them. If the condenser coils are dirty, they won't dissipate the heat effectively. As debris builds up on the coils, the refrigerator/freezer becomes less efficient, causing it to work harder to cool down. If the coils are significantly dirty, it will not be able to maintain the proper temperature. Check the condenser coils to determine if they are dirty. All models have coils in an enclosed area usually accessible via a vented cover at the back of the refrigerator. These coils help to keep the refrigerator and freezer cool. If these coils become too dirty from dust or other particles, the freezer may not work as efficiently.
unplug when taking the vent panel off to clean. bottle brush or a vacuum attachment be careful not to bend aluminium fins.
Jan 30, 2018 | Samsung Refrigerators
Samsung RB31F Fridge/Freezer - fridge temperature too high, freezer OK
1-The condenser coils are usually located under the refrigerator. They dissipate heat as refrigerant passes through them. If the condenser coils are dirty, they won't dissipate the heat effectively. As debris builds up on the coils, the refrigerator becomes less efficient, causing the refrigerator to work harder to cool down. If the coils are significantly dirty, the refrigerator will not be able to maintain the proper temperature. Check the condenser coils to determine if they are dirty-if the condenser coils are dirty, clean them.
2-The evaporator fan motor draws air over the evaporator (cooling) coils and circulates it throughout the refrigerator and freezer compartments. Some refrigerators have more than one evaporator fan motor. On refrigerators with only one evaporator, the evaporator is located in the freezer compartment. If the evaporator fan is not working, it will not circulate the cold air to the refrigerator compartment. If this occurs, the freezer may still get cold, while the refrigerator will not get cold. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor.
Oct 29, 2017 | Samsung Refrigerators
Freezer fine, fridge not cooling
This sounds like a small Freon leak. It could come from cleaning the coils, or movement by the compressor. A technician with a gas tester (locator) can find any small leaks and repair that section. The cost is not excessive and a new unit is over $1000, so consider the options.
Mar 10, 2014 | GE GTS22WCP Top Freezer Refrigerator
Westinghouse freestyle fridge &freezer work but warm after being turned off fo 90 days
What happens in that 72 hours is the evaporator coil get's so much frost built up on it that the fan in the evap. freezer fan has no where to circulate the cold air (where the cold is produced). Basically you have a restriction between freez/fridg. sections you have defrost problem> It is one of three things d heater,d t stat, or your d timer.I need the model # to tell you what my sugestions would be and where to start.
Nov 15, 2013 | Refrigerators
I have a two year old samsung side by side refrigerator RSA 1DHMH. The freezer department has suddenly stopped producing ice and the temperature has risen significantly that food as now thawed. I have...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 25, 2011 | Samsung RS2534 Side by Side Refrigerator
I have a Kenmore refrigerator side by side model 106.53582300, purchased Aug 2003. It's been working perfectly until about 3 days ago, very suddenly, neither freezer nor fridge is cold. There is air...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 10, 2010 | Refrigerators
Fridge not keeping cold..
Check the coils underneath the fridge. Carefully vacuum and brush the coils clean. Usually there is a condenser fan near the compressor and condenser and a evaporator fan in the freezer. Make sure they both are turning.
Jun 21, 2010 | Electrolux E23CS75DSS Stainless Steel
Maytag fridge isn't cooling
I recommend that you do preventive maintenance by cleaning the cob webs and dust accumulation from the coil located on the bottom of the refridgerator. The coils can be seen from the front of the fridge at floor level behind the removable plastic grille cover. The coils need to be also cleaned at the back of the fridge located near floor level, usually covered by a black colored, cardboard material cover that is removable. First start your cleaning process with a vacuum and hose attachment and clean as much as possible of the large debris. Second. use compressed air along with the vacuum to blow out any debris that could not be reached in the first step. Turn thermostat settings for fridge and freezer back to normal settings and allow time for temperatures to reset.
Jun 26, 2009 | Refrigerators
I cant get my fridge settings right it is either freezing everything or starts leaking
The first thing to do is a complete defrost. This requires emptying the freezer, fridge, doors open, plug out. The freezer should drain to a tray in the dusty area under the fridge. Vacuum the coils while you're there.. If it doesn't drain to there, you have a stuck drain. If it's just ice, it'll melt sooner or later. It could be a pea or something stuck in there. You have to remove the freezer inside cover to find out, a lot of trouble. If you do, check the defrost coil, they break easy. Sometimes the defrost timer breaks. If you can find it, it should turn the compressor off and the defrost coil on once a day. The fan and lite will still work.
Aug 18, 2008 | Frigidaire Refrigerators
I have a 2 year old SMEG FAB 32 Fridge/Freezer and the freezer section has suddenly lost temperature. Upper frdige section is fine but freezer not. I have emptied, kept door shut, turned dial up but no...
I have a 2 year old SMEG FAB 32 Fridge/Freezer and the freezer section has suddenly lost temperature. Upper fridge section is fine but freezer not. I have emptied, kept door shut, turned dial up but no success.
Any suggestions on what the problem might be?
Wouldn't expect problems on a SMEG just 2 years old.
You could have a bad thermostat or the refrigerator could be low on Freon, make sure you clean off the exposed coils on the back of the fridge and underneath to free it from dust and dirt – use some type of a blower for underneath and the coils you can vacuum off or wipe off the coils, if not call a service tech to have a look @ the refrigerator – it might have a bad compressor
Apr 14, 2008 | Refrigerators
Refrigerators Logo
184 people viewed this question
Top Kenmore Refrigerators Experts
gbob59
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
