Question about Whirlpool Washing Machines
I have a whirlpool washing machine model number 6ALSR7244MW4 I need a agitator cam kit but the closest one I can find is for model 6ALSR7244MW3 will this fit also found a part 285811 will this fit
Posted by Toni Moss on
Jimmy
    Scholar:
  • 61 Answers
Hi Toni, part kit 285811 will fit your machine. If you only need to replace the worn dogs you should order part number 80040. Hope that helps.
Posted on Jul 01, 2019
3 Related Answers
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: The agitator on my Whirlpool washing machine does move
The agitator has a set of dogs that are easily replaced. 71e0cea.jpgTake a look at these repair pix
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Aug 20, 2009
greenspan
Remmy Moore
  • 1734 Answers
SOURCE: whirlpool washing machine 6ALSR7244MW3. screw
Find the service manual for your machine here
I searched this for you, pls leave a good rating.
Posted on Oct 12, 2009
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: Need help replacing the Agitator/Mover
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
The agitator is slipping
You need to replace the agitator cams. Go to appliancepartspros.com put in your model number and you will see agitator repair kit. Comes with everything you need to fix and instructions. Cost $10.00
Aug 09, 2010 | Whirlpool Washing Machines
Agitator disengages intermittently during washing. During the wash cycle it makes a noise like it's unbalanced. Opening lid to watch washing shows the agitator being engaged in fits and starts. ...
On a Whirlpool manufactured washer, the problem may be very simple, inexpensive and easy to repair.
Whirlpool uses a split agitator design. The upper portion is called the auger, while the bottom is called the agitator. Between these components is a agitator cam assembly. This problem is commonly caused by either worn agitator dogs, a worn agitator cam assembly, or a loose agitator bolt. The following link explains what the dogs are and how to replace them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
The part number is included in the link provided. You can purchase replacements at pcappliancerepair.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the thrust bearing, and the dogs for about $11 or $12.
NOTE: You can refer to the excellent exploded view parts diagrams the web site has to offer for assistance. Whirlpool also recommends the application of a little grease on the thrust washer. The part number for their recommended grease is AP3098553.
If you have any questions about this repair, please post back with your complete model number (located on a nameplate along the wash tub opening under the lid) and let me know. I hope this helps you.
NOTE: DO NOT overtighten the agitator bolt. This can cause damage to the plastic, or restrict the agitator movement. Tighten until snug only.
Jan 04, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
The top part of the agitator won't turn but the bottom will. what do i do?can i remove the top part and replace a gear?
Whirlpool has a split agitator design. The upper portion is called the auger, while the bottom is called the agitator. Between these components is a agitator cam assembly. This problem is commonly caused by worn agitator dogs or the agitator cam assembly. The following link explains what the dogs are and how to replace them:
The part number is included in the link provided. You can purchase replacements at pcappliancerepair.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the thrust bearing, and the dogs for about $11 or $12. IMPORTANT NOTE: The model number you have this question listed under did not have the split agitator design. It used a single piece agitator with a center post cap installed. If you need further assistance in identifying parts, please post back with your complete model number (located along the wash tub rim under the lid).
If you have any questions about this repair, please let me know. I hope this helps you.
Dec 22, 2009 | Whirlpool LSR5132PQ Top Load Washer
Good afternoon - I have a Whirlpool model LSR7233EQ0 washer. The washer works fine in regards to draining, filling, lower agitator works...however, the top agitator does not engage and almost sounds like...
Whirlpool uses a split agitator design. The upper portion is called the auger, while the bottom is called the agitator. Between these components is a agitator cam assembly. This problem is commonly caused by worn agitator dogs or the agitator cam assembly. The following link explains what the dogs are and how to replace them:
The part number is included in the link provided. You can purchase replacements at pcappliancerepair.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the thrust bearing, and the dogs. For the model number you have listed, the part number for the kit is 285811 and sells for about $11.
Dec 16, 2009 | Dishwashers
Problem for Whirlpool LXR9445JT Top Load Washer Whirlpool top-loader LSQ9200LQ0 The top half og the agitator is not turning.
Dec 14, 2009 | Whirlpool LXR9445JT Top Load Washer
The agitator seems to be loose. It washes, spins and gets rid of the water, however the agitator seems to be loose. Is there any way of tighting it up or do I need to buy a part of some kind?
Your problem may just be attributed to a loose agitator bolt, or the agitator dogs require replacement.
Roper (which is manufactured by Whirlpool) has a split agitator design. The upper portion is called the auger, while the bottom is called the agitator. Between these components is a agitator cam assembly. This problem is commonly caused by worn agitator dogs or the agitator cam assembly. The following link explains what the dogs are and how to replace them:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
The part number is included in the link provided. You can purchase replacements at pcappliancerepair.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the thrust bearing, and the dogs. If the model number you listed this under is correct, the part number for the kit is 285811 and sells for about $11.
NOTE: DO NOT overtighten the agitator bolt. This can cause damage to the plastic, or restrict the agitator movement. Tighten until snug.
Dec 05, 2009 | Roper RAS8445KQ Top Load Washer
The agitator does not completely rotate unless you press down on it.
If this is a Whirlpool manufactured top loader with a split agitator design, this is commonly caused by worn agitator dogs. The upper portion of the agitator (called the auger) has a cam assembly with small agitator dogs that act as a clutching mechanism to drive the auger during the wash cycle. They wear out over time and need to periodically be replaced. The following link explains what they are and how to replace them:
The part number is included in the link I provided. You can purchase replacements at appliancepartspros.com for about $5. For a little more you can purchase the entire cam replacement kit which includes the dogs, cam, seals and washers.
If you have any questions, please let me know. If this is not a Whirlpool manufactured washer (which includes Kenmore, Roper, Estate, Frigidaire, Kelvinator) please let me know. If you are in doubt, please provide a model number and I can confirm for you. I hope this helps you.
Oct 04, 2009 | Washing Machines
Top part of agitator stopped working
They make agitator repair kits with the reversing dog ears and retainers. The only item number that I can come up with is 2921. You can order them from most appliance parts dealers. You need to determine if you need the one for long cam or short cam. Hope this helped somewhat. Good luck.
Jul 16, 2009 | Washing Machines
TOP AGITATOR NEEDS TIGHTENING
You need to get an agitator repair kit from the appliance parts store. Number ap3138838 This has a new thurst washer that will fix the loose upper agitator. Remave cap under fabric dispenser, it pulls up and you will see bolt. This kit also has cam parts to repair the worn ones on upper agitator too. Take model number to the store with you.
Jun 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
98 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
