Question about Furniture
Need relay part for uberhaus design wine cooler.Part no QP2-4.7
Posted by Amarjit Gill on
5 Related Answers
bobotfel
Felizardo Erilla
  • 241 Answers
SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Posted on Jan 21, 2008
Anonymous
SOURCE: Haier Wine Cooler won't cycle on and off automatically
Hey all,
For those of you who have problems with one or both or your zones not cooling on the HVTB18DABB or similar wine cooler/cellar, the problem lies the Peltier-style thermoelectric cooling module. The original part is "TEC1-12706" and information on it can be found on google. Finding this or a similar part on ebay can be done by searching for "thermoelectric cooler". If the exact TEC1-12706 part cannot be found, then any similar part that's 40mm x 40mm in size, and 51 to 69 watts should do fine. For $25 I was able to get 3 modules...one to replace the bad zone I had, and then I'll have 2 spares in case the other zone, or this new one, ever go bad again.
To replace the part you must remove the back panel from your Wine cellar. You will see 2 big fans attached to two large heat sinks. (If a heat sink on the back does not feel warm to the touch, the the other side is obviously not cooling, which means that zone is broken.) Remove the screws from the fan and the heat sink of the zone that is not cooling, and while holding the heat sink, pull the whole cooling assembly for that zone out. Dont be alarmed if you feel some insulating foam separating as you pull it out, its a tight fit so that is to be expected. Once you have the cooling assembly out of the fridge, take it apart and you will see the square ceramic cooling module inside. (REMEMBER which way the module was oriented before you remove it, so you know how to put the new one in.) Clip the red and black wires near the module and remove it from the assembly. DON'T wipe away any of the white thermal grease left behind on the heat sinks. If you have any extra thermal grease handy (available at Best Buy, or online at sites like newegg), apply an extra pea-sized dab to both sides of the new module. Put the assembly back together and splice the wires from the new module to the loose wires left behind going into the back of the Wine cellar. Mount everything back in place as before, close up the back, and youre done!
This is really a lot easier to do than it sounds, especially if you're comfortable doing this sort of thing...a few pictures would explain much better if anyone wants to illustrate.
These are actually great units, so I hope this helps somebody fix theirs!
Posted on Sep 24, 2008
localwonder
Michael Masters
  • 6784 Answers
SOURCE: Need user manual for Emerson Wine Cooler FR23RD
HI. i couldn't find the FR23RD but, i have been told that this manual covers your model. It basically covers FR24SL threw FR24RD. Your model is also covered in this edition. Click to review your manual.
Please rate and god bless.
Posted on Mar 22, 2009
Anonymous
  • 259 Answers
SOURCE: Are red wines stored on the top or bottom of the
http://www.haieramerica.com/en/asset/archived/BC112G.pdf
is the link to your manual.Typically in a dual temperature zone wine cooler whites are stored in the bottom and reds on top as whites are better a little colder and the cold air will drop to the bottom of the unit.
Hope this helps!
Posted on Jun 14, 2010
qasolution
jeff bennett
  • 107 Answers
SOURCE: where is the main power relay?
the current is running in the wrong direction here is a site that shows how thermo cooling works.http://www.activecool.com/technotes/thermoelectric.html
Posted on Apr 22, 2012
Where can I get a relay for a wine cooler model jc 145b2eq? Uberhaus
its not the good number but try there http://www.searspartsdirect.com/partsdirect/part-model/Danby-Parts/Wine-beverage-cooler-Parts/Model-DWC612BLP/3055/0169000?pathTaken=&prst=0&shdMod=DWC612BLP
Apr 24, 2014 | Furniture
What is a compressor based wine cooler?
A compressor based wine cooler is similar to a little refrigerator from the outside and from the inside but it designed to be suitable for wine bottle storage in the exact temperature, in comparison to the other in the market the compressor based wine coolers are much more expensive.
Aug 14, 2012 | Furniture
What is a build-in wine cooler?
A build-in wine cooler is designed to be built into exiting counter and cabinetry. Build in wine cooler includes a front ventilation system which channels the heat forward from the unit, just like any other wine cooler.
What is a freestanding wine cooler?
Freestanding wine cooler designed to stand alone without been attached to the wall. Freestanding wine cooler includes a front ventilation system which channels the heat forward away from the unit.
What is the difference between a freestanding and built-in wine cooler?
A freestanding wine cooler is designed to stand alone whereas a built-in wine cooler is fitted into existing counters/cabinetry.
Jul 31, 2012 | Furniture
Can the U-Line 15WC Wine Captain be converted to a beer cooler? Can it be adjusted so that it gets colder?
Here is a couple of reason that answer is no. One the thermostat is designed for 45 - 60 degrees. 2 The door is only design for those temperatures as well. I believe you are going to need the bee around 34 degrees. A wine captain would never make it. Its also design for 3 different temps at once. coldest on bottom and warmest on top.
Aug 22, 2009 | U-Line 15WC Wine Cooler
Magic Chef MCWC8DSCT Wine Cooler
the magic chef is probably the ptc relay.to the left of compressor is a shield with 1 screw behind it .on top is the relay with 1 wire.wiggle it off .go to repairclinic.com...part#1206838
Nov 07, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Danby DWC283BLS Wine Cooler - Error message E3 & E4
Is the compressor running? I don't know this unit, but know that if you are too warm that is the first thing to check. In reading about another unit that had a different problem, it was mentioned that there is a ciruit board. If it has relays on it then these are the most likely culprit. They are either not making contact or staying in contact too long... sometimes just tapping each relay usually a black plastic component will cause it to work intermittently..Not sure if you can get these but call the company help line at 1-800-263-2629.
Jun 12, 2007 | Danby DWC283BLS Wine Cooler
Furniture Logo
210 people viewed this question
Top Furniture Experts
Tom Chichester
ray gallant
Are you a Furniture Expert? Answer questions, earn points and help others
