Question about Home Security
Where is the power button on DH41NK - Home Security
Posted by Corky Delahoussaye on
Vincent Migliore
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 36 Answers
Open the unit and trace the power cord connection from the wall plg wire to the FIRST connected control inside the unit. Voila!
Posted on Oct 09, 2019
PLEASE I USE IRULU BUT I WAS TRYING TO REINSTALL IT BE IT WENT OFF NOW HAVE CHARGE THE PAD BUT HARD TO REINSTALL PLEASE HELP.
You need to fully charge the tablet and THEN do a factory reset. The hardest part is waiting.
Follow the steps provided below to perform a Hard Reset on your iRULU Android Tablet:
  1. Turn your iRULU tablet off.
  2. Press and hold the correct key combinationto boot your Android tablet into Recovery Mode.combinations, which include:
  • Home button + Volume Down button + Power button
  • Power button + Volume Down button
  • Power button + Home button + Volume Up button
  • Power button + Volume Up button
  • Power button + Volume Up button + Volume Down button
  1. Release the power buttons once your screen turns on, and the device vibrates. Keep holding the other buttons for 10 seconds.
  2. Your Tablet should now boot into Recovery Mode.
  3. Scroll down to the 'Factory Reset' option using the volume down key.
  4. Select the 'Factory reset' option by pressing the power button.
  5. Now your Tablet will start the hard resetting process.
Once the process begins DO NOT press any buttons and don't try to turn the device off.
Your tablet should now be reset.
Oct 22, 2018 | Tablets & eReaders
I have a canon pixma mp250 and error P07 flashing.Now,I refill blac and colour cartridges,and clean ink absorber,but still flashing P07.How to reset printer? Best regards, Misko
its mean absorber full..(i think)
Check this steps :
1: Unplug power and USB
2: Open door and hold power button.
3: Connect power.
4: Close door, then release power button
5: Connect USB and an press power to use.
1 Press the power button to turn off the printer.
  • 2 Hold the "Stop/Reset" button while pushing the power button. While still holding down the power button, release the "Stop/Reset" button and then push it twice in a row.
  • 3 Wait approximately 20 to 30 seconds until the LED shows 0.
  • 4 Push the "Stop/Reset" button four times in a row.
  • 5 Push the power button twice.
  • 6 Turn off the printer by pushing the power button one more time. The printer is now reset. Next comes resetting the counter on the cartridge.
  • 7 Unplug the power and the USB cables from the printer.
  • 8 Open the cartridge door and hold down the power button.
  • 9 Reconnect the power cables while still holding down the power button.
  • 10 Close the cartridge door and release the power button. The ink cartridge is now reset.
  • Aug 11, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
    Moniter message power button lockout
    Power Button locked out means that the power button is locked.
    • If the power button is locked, press and hold the power button for 10 seconds to unlock the power button function.
    • If the power button is unlocked, press and hold the power button for 10 seconds to lock out the power button function.
    Hope this helps.
    Apr 12, 2011 | Computers & Internet
    What is combination for entering service menu on LG M1962D?
    1. Power off your monitor with POWER button
    - Hold MENU button and keep it pressed while pressing POWER button
    2. Press MENU button to enter Service menu
    3. Change panel type
    - Press SET button until PANEL text is yellow and press (-) two times to change it to LPL22W 4L
    - Press MENU button to close the Service menu
    - Press POWER button to power off your monitor and remove power cable for a minute and plug it in again
    Jan 18, 2011 | LG M1962D Monitor
    ERROR 5B00, no me deja imprimir
    1. Turn off the printer ( "Power" button).
    2. Hold the button "Resume" (red circle in the triangle) and push "Power" button.
    3. When printer become ready hold the button "Power" and release button "Resume".
    4. Push button "Resume" 2 times and then hold "Resume" and release "Power" button.
    5. When I hold button "Resume" I push and hold "Power" button and release "Resume".
    6. When I hold "Power" button, push button "Resume" 2 times and release both buttons.
    7. When printer become ready on the display write "CANON Idle".
    8. Push button "Resume" 4 times.
    9. Then push "Power" button 3 times to turn off printer.
    All done. The printer is ready to print.
    Nov 22, 2010 | Canon PIXMA MP180 All-In-One InkJet...
    Canon ip 4200
    1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button.
    (DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
    2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
    3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and
    Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
    alternately, Alarm in orange and Power in green, starting with Alarm LED.)
    4) When the Power LED lights in green, press the Resume/Cancel button 4 times, the green (power) led should be lit to reset ink absorbers.
    (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
    5)At the end of the service mode, press the Power button
    Jan 10, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
    Canon ip4200 waste absorber is full
    Jan 10, 2009 | Office Equipment & Supplies
    Waste absorber is full in canon iP4200?
    Follow this instruction:
    4) When the Power LED lights in green, press the Resume/Cancel button 4 of times.
    5) Then press the Power button, then press it one more for turning off printer.Restart the printer and it will printing again.
    I have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray...
    same equql problem....?????
    Can you help?
    i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. Can you help? thanks thanks
    Dec 21, 2008 | Televison & Video
    Error number 1700 canon s9000 printer
    knowing printer manufacturers I doubt they even have a sensor to detect that its full at all, they probably based on something crumby like print count. here are some instructions to reset the waste ink tank, the instructions vary so try them until one does the job :
    Waste Ink Tank Reset
    1: Power off printer
    2: Hold Resume button then press and hold POWER, the beeper will sound once.
    3: Hold POWER and release RESUME
    4: Press RESUME twice, then release all buttons
    5: When the indicator lights steady, press RESUME three or four times. The indicator should be orange.
    6: Press Power to set data
    1. Turn off printer
    2. Hold down Resume button and press Power button.
    3. Keep holding down Power button and let Resume button go.
    4. Press Resume button 2 times then let BOTH buttons go.
    5. Green lights will flash and then stop blinking.
    6. When green lights are solid, press the Resume button 4 times.
    7. Press the Power button and the printer should turn off, if not, press the Power button once more.
    8. Your printer should respond as normal.
    1. power off Printer
    2. Push and hold resume button and push power button
    3. Hold Power button and release Resume button
    4. Push Resume button twice ( 2x ), and now release resume button and power button
    5. Green light will blinking and stop.
    6. When green light on, push resume button 4 x
    7. Push Power button and printer will off, if that isn't off, push power butto again until print off position.
    Aug 20, 2008 | Office Equipment & Supplies
    Home Security Logo
    163 people viewed this question
    Top Home Security Experts
    Marvin
    Marvin
    Tom Chichester
    Are you a Home Security Expert? Answer questions, earn points and help others
