Question about Garden
The mower has a vibration when I ingage the mower blades.
    Novelist:
  • 209 Answers
Bent blades or damaged blade spindle
Posted on Jun 30, 2019
  • 1,016 Answers
6ya staff
SOURCE:
Anonymous
  • 4 Answers
SOURCE: I have a craftsman dlt2000 mower and the blades r
could be a belt problem
Posted on May 18, 2009
Jeff Howe
  • 84 Answers
SOURCE: will not move
the belt running to the back tires has either slipped off r broken off. to get to it you simply go to the back and remove the plate in between rear wheels.
Posted on Jun 24, 2009
Anonymous
SOURCE: 2206 CUB CADET RIDING MOWER BLADES WILL NOT INGAGE
Having had the same problem on mine, it turned out to be the connection to the fuse under the instrument panel. After I cleaned the contacts on the fuse, it worked great. Also, I had to eventually apply some contact grease to keep it from repeating the problem every couple of weeks. Since then, I haven't had the issue for 2 years.
Posted on Sep 01, 2009
Anonymous
  • 110 Answers
SOURCE: VIBRATION-THRU SEAT & FOOT RESTS AFTER ENGAGING BLADE
get down and gun your fingers in the slot that the belt rides in, soulds like you may have a small rock or piece of wood lodged in the v part of one of the pulleys. I bet thats it Jim
Posted on Dec 19, 2009
Andrew White
  • 2239 Answers
SOURCE: my mod. 917273220 starts fine and runs great but when i ingage the clutch it kills the engine. the mower blades do not move
Problem with the micro switch under the drivers seat, clean/replace.
Posted on Mar 08, 2012
John deere d140 lawn mower shoots of when i ingage the blades
Here's the link and I'm sure you will get the solution of your problem.
JOHN DEERE D140 SERVICE REPAIR MANUAL
May 04, 2017 | John Deere Garden
Craftsman excessive vibration lawn mowers problems
vibration in a walk behind mower is most always a imbalance in the blade , there lots of things that cause this , from loose blade , to bent blades
remove blade and test with blade balance , there not expensive ive seen them with a sharping stone for less than ten dollars before
pull spark plug before you remove blade 4 safety
Jun 07, 2014 | Craftsman 675 Torque 190cc 21" Briggs ...
Blades wont ingage
I would check the belt, the pulleys and the tension of the pulleys. Any of these could be the cause of your issue. Hope this helps!
Jun 08, 2012 | Husqvarna YTH23V48 23HP Lawn Tractor 960...
Honda HR215 hits stump - still runs and cuts but engine vibrates when running IF the BLADE IS NOT TURNING.
you could have bent the blade or the crank look at the blade then remove the blade mount and spark plug turn on its side and turn the engine over and look for crankshaft runout
Apr 07, 2012 | Garden
Very bad vibration when engaging the blade
Bad vibrations when engaging blades is usually caused by an out of balance blade. Out of balance blades occur due to damaged and/or bent blades. The fix is to find and replace the offending blade.
Jul 19, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
Jul 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Motor vibrates the entire mower, new motor pulley; belt and deck pulley replaced by serviceman. Continues to vibrate. Craftsman YTS 3000
Doesa the vibration happen when the cutting blades are engaged or do you still have vibration when blades are not turning? IF BLADES ARE TURNING AND YOU HAVE VIBRATION, YOU NEED NEW BLADES OR THEY GOT BENT FROM HITTING SOMETHING HARD AND NEED TO BE STRAIGHTENED OR REPLACED. If vibe is there when blades are still, possibly the output (crankshaft) is bent. Goodluck, Macgivor
Oct 24, 2009 | Garden
Not ingaging
Check to see if the belt might have come off and wedged on something under the frame. Or,,maybe a spindle could be locked-up. One more thing to check is if your deck might have a braking system on it to keep the blades from moveing it might not be disingaging.
Aug 22, 2009 | Garden
What ingages blades ,blades not engage
On most riding mowers flipping the handle to engage the blade causes an idler pulley to engage the drive belt, which takes up the slack in the belt and pulls it against the drive pulleys. A few odd-balls have an electric clutch to engage the blades.
Jul 10, 2009 | Garden
Electric lawnmower
Need to check blade and replace.Blade is out of balance causeing vibration. If you continue to use cener shaft bearing will also wear out and cause vibration. Buy new blade and if vibration is still there return blade.Mower is not worth bearing replacement. Buy new mower.
Please take time to rate .Thanks
Mar 28, 2009 | Electric Garden
Garden Logo
21 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
