SOURCE: power indicator is flashing
Possible error on JB board - diodes D5701, D5703, D9616. Replacing them should be sufficient. Anyway, you should contact the nearest Sony Service. Regards, Arpi
SOURCE: Lamp
red light indicates lamp is expired. even though you get temporary light, the lamp is shot. Try BULBMAN.COM for a new lamp.
SOURCE: HELP
I had the same issue. Replaced the lamp and now mine is working. Normally this is a sign that the bulb is out, however - I would say now that either:
1. Your lamp is defective.
2. The balast in your TV is defective.
I would check out Discount-Merchant.com - they can help.
SOURCE: lamp indicator flashes three times even with new lamp.
Check your manuel for Lamp counter reset facility , lamps sometimes will not retsrat untill this is done ... Regards Vortash
SOURCE: Malfunction Indicator Lamp
Take your car to your local autoparts store and have them pull the codes - this is free at most stores. Post the codes when you're done. This can be caused by anything - even as simple as not tightening your gas cap (you should hear the clicks - it doesn't damage the cap).
