Question about Kicker Car Audio & Video
SOURCE: amp getting really hot
If depends on what the amp is rated to run. If it is only rated to run 2 ohms x2ch then it can only run 4 ohms x1ch. If you run it at 1 or 2 ohms that is too low, too much current, and it will get hot and eventually blow up under hard use. Some quality amps can live that way, and it depends on the sub and what frequency you are running it at. For normal use I would not recommend it. Wire to sub at 4 ohms x1 (or 2 ohms x2ch) for that amp if that is what it is supposed to be at, I'm not sure from your description. Also enhance cooling of the amp if you can, I run fans on mine if they have a heat issue. Warm is one thing, hot is another and not good for amp.
Posted on Apr 22, 2008
SOURCE: got a 12"kicker L74ohm sub and sony xm-D9001GTR mono amp
Hello juan_penaloz,
The Kicker L7 has an RMS power range of from 50-750 watts and a maximum power handling capability of 1,500 watts so your Sony amp will power it OK. A more powerful monoblock like the Alpine MRP-M1000 or the Kicker 08ZX750.1 would provide even more power and could operate safely at 2ohms.
You have the voice coils wired properly for the Sony amp. It's OK to have the sub impedance higher, but you definitely do not want it lower than the 4ohms the amp is rated at in bridged mode.
Hope this helps.
Posted on May 26, 2009
SOURCE: sony xm-D9001GTR mono and kicker 4ohm dual voice coil
its a good amp but dont power ur amp at full put it at about half power
Posted on May 27, 2009
Oct 09, 2016 | Kicker Car Audio & Video
Dec 30, 2014 | Car Audio & Video
Nov 19, 2013 | Kicker Car Audio & Video
Mar 08, 2010 | Kicker CompVX CVX122 Subwoofer - 12" Dual...
Jul 17, 2009 | Polk Audio DB1040DVC Car Speaker
May 26, 2009 | Sony XM-1252GTR Car Audio Amplifier
Jan 23, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Jul 26, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Jun 19, 2008 | Jl Audio 12W3 Car Subwoofer
Apr 20, 2008 | Power Acoustik PS2-1200 Car Audio...
Aug 17, 2018 | Kicker Car Audio & Video
112 people viewed this question
