Should be receiving and transmitting same time possible bad antenna
Usually resetting the 'Service' breaker on the main control box resolves this. If not, even though your remote receives data, you may still want to replace batteries in the remote. Next would be a faulty remote transceiver board ( cheaper to replace than the next item), in the unit with the antenna, or the mother board (the more expensive item).
SOURCE: NAD 7100 How to turn off low level without a remote
You can ONLY defeat this feature by modifying the circuit on the mother board. The remote availability has nothing to do with this feature on power on
SOURCE: Remote Control Extender from Radio Shack
To determine if your PC will simply not connect or if really your wireless AP/Router, please download NetStumbler,
install and run. The software will determine if there is an AP within
your immediate area (including yours/high signal strength), if there is
& it is yours, then it is configuration problem, it none or some
but weak (low signal/not yours) then it is a hardware problem and would
most probably require replacement. Most of the time, the cost/time of
repair would make the purchase of a new one more reasonable. If your
Wireless Ap/Router was detected by NetStumbler, then perhaps what you
need is to re-configure your system/set-up again.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional; information.
Good luck and kind regards.
SOURCE: 360 degree outdoor antenna radio shack
What type of antenna is this. You will need 75ohm cable for this with good 75 ohm 3 way splitter. Please be sure that TV cable is not going to work.
SOURCE: 3M Precision Digital Atomic Wall
After replacing the transmitter batteries several times, I tried replacing the clock batteries. They must have been getting low. Once I put in new batteries in the clock it worked fine. Good Luck.
