Question about Hotpoint Refrigerators
I HAVE A hotpoint fzs175 iT WAS BEEPING THE COMPRESSOR WAS WORKING. PUT THE BUTTON TO RESET,TURNED IT BACK ON. aLARM STILL BEEPING NOW NO NOISE FROM THE COMPRESSOR NOT FREEZING
Posted by Alan Lucas on
4 Related Answers
buddymcl777
Bruce McLeod
  • 67 Answers
SOURCE: Freezer compressor runs steady & getting -30F
You probably have a defective thermostat or sensor for reading the temperature.
Posted on May 01, 2009
Anonymous
  • 103 Answers
SOURCE: Freezer alarm stuck on - can't reset
Hi: Does the freezer have a battery backup for the electronics? A 9v. battery in the grill down below. You won't have to remove the grill but pull a small rectangular panel to expose the battery. High end Kenmore freezers have a battery to back up the alarm. The six you see is actually supposed to be a "b" for battery most likely. L.E.D.'s are tough to tell the difference. Buy an new battery and all will be well. I hope this helps, Jeff
Posted on Jun 12, 2009
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: hotpoint fridge freezer ffa60 red
Check to see if the fan near the compressor is running. It should run when the compressor runs. Spin it and it may start.
Posted on Sep 02, 2010
mike cooper
  • 884 Answers
SOURCE: How to stop alarm of freezer
Unplug it for about 10 minutes to allow any capacitors to dissipate. Switch back on. If alarm starts straight away, suspect faulty controller, probably caused by the spike in the power supply
Posted on Apr 20, 2012
Samsung refrigerator alarm beeping continuously
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
May 15, 2016 | Samsung Refrigerators
Model E402b. Why is the alarm going off?
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow Cause of Beeping Noise in Frigidaire Refrigerator eHow
Jun 02, 2015 | Fisher and Paykel Refrigerators
Alarm keeps sounding every 2.5 minutes, it works fine on electric, gas and battery and is 12 months old.
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
May 03, 2015 | Refrigerators
Why does my Hotpoint ff187e frost free fridge freezer lights flash and the alarm sound even after reseting them as per manual. rest them ok for a while but then restart what's the problem?
Jul 27, 2014 | Hotpoint Refrigerators
How to start a proton savvy with no chip in key housing
If not the battery (replacement) then check to make sure the transponder is not missing from the remote. Should be a small plastic to slot in the key. If still not working then you may need to reprogram it. It can only work if you have 2 set of keys to put in the ignition:
[1] Take the key that needs programming put it in the ignition and turn to the on position and then press and hold in the alarm reset button..
[2] While still holding in the reset button turn the ignition off and remove the key..
[3] Re-insert the key and turn the Ignition to the ON position.
[4] Release the alarm reset button and then press it in once..
[5] Now with the ignition still switched on take hold of your SPARE key and press the lock button on your spare key..the alarm should "BEEP" once..
[6] Now press the Lock button on the key that has lost its programming..alarm should "BEEP" again..
[7] Switch ignition off.
Try that it should work
Feb 21, 2013 | Cars & Trucks
I have a hotpoint freezer FZS175, the alarm is going off. I've followed the instructions, turned the thermostat to zero, waited, then back to mid-way, pressed the fast freezer button. The freezer
Just had exact same issue with our FZS175 upright Hotpoint freezer - could not reset the alarming state.
Tried defrosting (even though it didn't look like it needed it) but still no change.
Then found the shaft of the little plastic thermostat control knob had sheared off. The only way to tell this has happened is to remove the control panel cover (switch off at mains first of course).
Superglued the broken knob shaft back together, inserting a 1mm steel reinforcing pin (cut from a woodworking panel pin) to prevent it happening again, and all is now well.
I think I am in the wrong profession (British wildlife documentaries)!
British Nature Films Wildlife films of the British countryside
Mar 15, 2012 | Refrigerators
When i turn the key to lock my car the door locks but it does not beep or set the alarm. the windows completly stopped working and when i lock the car it will sometimes not lock at all
open tailgate...central locking pump/air compressor is situated rhs under mat against bulkhead.should make whiring noise if okay. now try this... put key in drivers door hold key over to lock position buttons should go down and any windows that are open will close...to reset system unlock/hold key over... all windows will open fully. then lock hold key over.all windows will shut.take key out.leave for 30 secs.....
Feb 11, 2010 | 2001 Volkswagen Golf
90hp 4 stroke suzuki outboard how do i reset the oil alarm?
TO RESET:
1. TURN IGNITION KEY ON
2. PULL OUT THE EMERGENCY STOP BUTTON 3 TIMES IN TEN SECONDS, A SHORT BEEP WILL BE HEARD IF CANCELATION WAS SUCCESSFUL. TURN KEY OFF AND PUT EMERGENCY STOP LANYARD BACK ON ITS BUTTON
Apr 11, 2009 | Sport & Outdoor - Others
Need instructions or a manual on how to stop beep mode on watch
To turn hourly beep on/off: Hold the RESET button (lower right) and press the MODE button (lower left). When the days of the week light up, the hourly beep is on; when the days of the week are off, the hourly beep is off.
To turn the alarm on/off: Hold the RESET button and press ST/STP (upper right). Alarm light will go on/off.
Mar 26, 2009 | Watches
WR30 Wristwatch
hello,if you have the little circle window on the left of your face,that will tell you if the alarm and chime are on.
to turn them off you must push and hold the lap/reset button and at the same time push the st./stop button:
1 time takes of the chime-hourly beep
2 times takes off the alarm tha you set
3x's puts the chime back and 4x's puts the alarm back on.
Jul 21, 2008 | Timex 1440 53591 Sports Quotient...
Refrigerators Logo
75 people viewed this question
Top Hotpoint Refrigerators Experts
jdthefixer
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
