Question about Health & Beauty
Scooter wheel keeps coming loose - Health & Beauty
Posted by Kent Perth on
What is the torque specification for the drive shaft to wheel hub nut on my mom's Jazzy?
Hi this happens with a lot of scooters u could try some LOCKTIGHT unsrew the nuts put the locktight on & tighten them up I use a 2 foot socket bar to tighten them ....good luck
Dec 15, 2015 | Pride Jazzy Select Gt Scooter
Scooter stopped while going up an incline. just slowed down and stopped. now when activated it just make a ratcheting sound. same after charging overnight
hi, now that could be a seized brake,,,, a faulty break so remove it but keep it connected... and test.
Regards
Rob
www.gewizrepairs.co.uk
Apr 29, 2014 | Pride Sundancer 3 Wheel Electric Scooter
Power shuts off when i sit on the scooter
Hi, it's only a loose connection or bad connection, pinpointing it will be harder, now turn over the scooter and check the wiring connections
from the battery connector to the controller mounted under the floor board, the best way is to have the scooter running while you move varoius cables but be careful of the wheels etc you will need someont to help you, take care...
Regards
Rob
Jan 02, 2014 | Shoprider Mobility Products, Inc. Hero...
Chain is loose and keeps coming off
check the chain for broken links, if there are any broken ones walmart sells a tool in the bike section to replace broken link for around $5 if there are no broen links check the sprokets for any broken pieces, otherwise you might just need to loosen the bolts for the rear wheel and have someone pull it tight while you retighten it
Apr 30, 2012 | Electric Razor Pocket Mod Scooter
Pride Celebrity 3 wheel. The free wheel lever
My Mother buggy does the same and you can damage the gearbox, so I use a elastic try down to the bumper this stops it from moving but should there be a need I can remove it.
the Freewhel mech may have come loose so check it out.
Regards
GeWiz.
Oct 12, 2009 | Pride Celebrity X 3-Wheel Electric Scooter...
Pride Legend scooter won't hold charge
check the wiring from the batteries as a wire could have come loose.
Regards
GeWiz
Sep 23, 2009 | Pride New Mobility Legend 4 Wheel Scooter
I just bought a revo three wheel scooter and it stopped going in reverse.
hi, the first thing to look at is the speed pot (wigwam), sounds like either it come loose so the pot is in the incorrect position or the track inside the pot is damaged or the wire for the reserse side has broken or come away.
Jul 25, 2009 | Pride Value Line Revo Scooter 3 Wheel
Just bought a used goped for my nephew, runs
i hve a MOB n73... \r\nand my seriaL NUMBER is 353548024388283
Can sum one tell me da license key of this serial number..... SMAR MOVIE 4.01
plz plz plz plz..... i Shall be thnk ful 2 all
Jul 06, 2009 | Go Ped Toys
Antitipping wheels dragging.
if there tires are the right pressure, sounds like the bar that holds the wheels has either come loose if possible or been bent downwards, I don't recommend you removing them.
Apr 18, 2009 | Pride New Mobility Celebrity 3 wheel...
Health & Beauty Logo
23 people viewed this question
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
ray gallant
Are you a Health and Beauty Expert? Answer questions, earn points and help others
