Question about Watches
How to change band on fit bit surge - Watches
Posted by Elena Webb on
Andrew Taylor
    Top Expert:
  • Watches Master
  • 33,373 Answers
How can I change the wrist of my new apple watch?
I guess that you can buy them on-line or in apple store but you can definitely change them, this is what apple say in their website: A different band can really change the look of Apple Watch. So we created a full range of them in a variety of materials. The grooves in each case are precision engineered and CNC machined to ensure a perfect fit with any band. And beautifully designed buckles and closures provide the perfect finishing touch.
Apr 16, 2015 | Apple Watch
Pins keep popping out when watch band gets snagged. What size are the pins for watch band?
mcdevito75 here, These pins may be a bit worn in the band of your watch, if so, you"d have to order a kit with various size pins for replacement. BEST BET, look for a small watch repair shop to fit new pins in the band.
Jul 12, 2010 | Timex Ironman 30 Lap 53952 Wrist Watch
Skagen watch band pins I've remove/changed spring pins other watches several times before but for this watch nothing happening How is it done?
they are very tough they have more pressure on them than most spring pins also on your watch they are tucked into the leather very well. the best way is with a spring tool apply quite a bit of pressure. a normal watch band will not fit this watch. it will only take skagen replacement bands.
http://www.skagen.com/service/home.fx
Jun 24, 2010 | Skagen Titanium Rectangle Watch Dial...
I need to change my watch band
Where the band meets the watch - push the band a bit to expose the pins that hold it on.. The pins are spring loaded and will compress with the push from a tiny flat screw driver..
You can get replacement bands at most retal stores..
OR - take the watch to WalMart jewlrey dept and find a band that fits and they will help you chang it..
Good luck ;o)
Sep 16, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
How do i change watchband for casio bg169wh
Take the watch with the broken watchband and place it on the table. With a ruler, measure the width of the broken band at the point where it is attached to the watch. Now, measure the total length of the watchband when it is in one piece and fits around your wrist. There will be a crease on the band where it is normally buckled.
  • Step 2 Go to the local store and select a band that you like. You should make sure that the width of the band at the point of attachment to the watch is the same as the old band. Also make sure that the new band will be long enough and not too long to fit your wrist. Purchase the band and return home to change the band.
  • Step 3 Clear a spot to work and make sure that there is a small towel covering the table top so that you can see anything that may drop or pop out during the process of changing the band.
  • Step 4 Use a magnifying glass to look at the point where one side of the band is attached to the watch. You will see a small pin connecting the band to the watch on either side of the band. Carefully use the jeweler's screwdriver to depress the spring loaded pin from the watch to the band and release it from the watch. When the tension on the spring pin is released it may pop out of the band and you will want to take care not to lose it. Repeat this process with the other half of the band.
  • Step 5 Take the new band and slip the spring pins into the small holes on the end of the band where it will attach to the watch. Working with one end at a time, slip one side into the pin hole in the watch body.
  • Step 6 Use the jeweler's screwdriver to depress the other side of the spring pin and guide it into the pin hole in the other side of the watch body. Repeat this process with the other half of the watchband and other spring pin. You now have a new band for your broken one.
  • Jun 20, 2009 | Casio BabyG BG169WH3V (Size: ) Watch for...
    Watches Logo
    171 people viewed this question
    Top Watches Experts
    Janelle Schoonover
    Janelle Schoonover
    Bruce Robin
    Marvin
    Marvin
    Are you a Watch Expert? Answer questions, earn points and help others
