Question about Russell Hobbs Coffee Makers & Espresso Machines
Fault with russell hobbs washing machine error code E8
Posted by Lucy Conteh on
5 Related Answers
Anonymous
  • 120 Answers
SOURCE: russell hobbs electric coffee percolator cord require a new cord
Go to a parts store and pick up a new cord.
Posted on Oct 08, 2009
mastermaid
Diane Pflug
  • 502 Answers
SOURCE: manual for Russell Hobbs breadmaker 4461
Ask the breadmaker manual search engine:
manualfox.com/searchengine/breadmaker.htm
If they find it, they will provide you a direct download link.
Posted on Sep 09, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: E8 error code
8E - OVER CURRENT ERROR
IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
IPM: Integrated power module. The IPM controls the motor.
If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
If the motor stops working, in one direction ten times, "8E" Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error "8E" is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power Switch OFF can clear the overload error.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
john_cross
  • 6277 Answers
SOURCE: I have lost the manual
Methinks you could do with another manual for your washer- for now and probably later! Sorry but FixYa cannot do that direct - members of the forum are just people from all over the world, probably working from home, and not representing any particular manufacturer ;-0)
By the way normally a spin speed is a spin speed regardless of whether there are whites or others inside. It really depends on the material which is being spun as to how much is spun out and drained. If the maximum spin speed has not spun all of the water out another spin is not likely to either - just waste electricity ;-0(
If your garments are still wetter than you would expect after spinning it COULD be that there is water still left in the drum i.e.not completely drained because of a blocked filter/drain pump. If this is so come back to me and I will send you my pre-typed guidance notes on cleaning/clearing blocked filters/drain pump/motors.
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Sep 03, 2011
ercupa190
ernesto cuadra
  • 12223 Answers
SOURCE: Russell-Hobbs 18140 4 slice compact toaster
See the diagram attached:
You will see the fuse you will problema 1) Ground 2) Live wire touching the chassis 3) Heating elements in short 4) Control Relais in short. 5) Test Diodes,You must test every components.God bless you
Posted on May 19, 2012
How to enter code
instructions - Russell Hobbs
uk.russellhobbs.com/pdf/14590_stylis_black_kettle.pdf
2 Don't put the kettle, stand, cable, or plug in liquid. ... 4 Don't open the lid while the water is heating. 5 Don't ... 8 Put the kettle on the stand - take care not to spill. .... To avoid environmental and health problems due to hazardous substances in electricaland electronic goods, appliances marked with this symbol mustn't be.Missing: code
Kettles - Russell Hobbs
en.russellhobbs.com > Our Products
Over the decades, Russell Hobbs has been at the forefront of quenching our national thirst for hot beverages with fast, easy to use, great looking electric kettles.Missing: open ‎question ‎enter ‎code
Russell Hobbs KE9000S Electric Kettle, Stainless Steel
www.amazon.com/Russell-Hobbs...Electric.../B00A15...
Amazon.com, Inc.Amazon.com: Russell Hobbs KE9000S Electric Kettle, Stainless Steel: Electric ...
Jan 13, 2016 | Russell Hobbs Kitchen Appliances - Others
Which button is spin on my russell hobbs rh1042 washing machine
The second to last on the dial (picture of a spiral), if it's the same as mine.
Nov 06, 2013 | Russell Hobbs RH1042 Frontload Washing...
My washing machine russell hobbs rh1042 gets half way in to a cycle then stops and lights start flashing what does this mean
Your machine is trying to tell you something-do you have the owners manual-if you don't I'd bet you could find it online-what I would look for is an explanation of the flashings-it will probably tell you to count the number of flashes to tell you what is going on-cheers denny
Oct 24, 2013 | Russell Hobbs RH1042 Frontload Washing...
Coffee Makers & Espresso Machines Logo
121 people viewed this question
Top Russell Hobbs Coffee Makers & Espresso Machines Experts
Paul Bade
ray gallant
deton8 von Splosion
Are you a Russell Hobbs Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
