Question about Tag Heuer Aquaracer Watches
My Tag Heuer Aquaracer stopped running. It never fell down or soaked as of today.
Posted by Joey Abraham on
5 Related Answers
Anonymous
SOURCE: Tag Heuer Aquaracer calendar problems
You have to unscrew the knob first then you will be able to pull it out to change the minutes, hours, date. You may have to use a pair of small pliers to initially turn the knob.
Posted on Mar 17, 2008
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: looking for the user manual for Tag Heuer Aquaracer watch
They were just hiding it:
http://ww2.tagheuer.com/_documents/manuals/EI2252_en.pdf
-Tha Mp3 Doctor
Posted on Dec 31, 2008
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: My tag heuer aquaracer has a problem: the second
Your TAG is fitted with EOL (end of life) feature. This is the cause of that 4-5 seconds interval movement of seconds hand and thus indicating the time for battery replacement. The timekeeping is not affected by this- it is just warning to replace battery a.s.a.p.
Find your nearest watchmaker and ask for battery replacement.
Do not forget to rate, please.
Posted on Mar 11, 2009
Anonymous
  • 11 Answers
SOURCE: Dont know how many time to wind it
until it begins to feel just slightly taunt,Do NOT over wind a wind-up wrist watch, if its a self winding you should just have to walk in it to wind it. here is a link to a pdf of your manual which has winding procedures, Good luck Jon click here
Posted on May 21, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: How to adjust the steel band on my Tag Heuer
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Jul 31, 2010
If the stem does not lock in, will it still be waterproof?
You need to get out your jeweler's loupe (best at 5x & 10x)... and look for the threads to "*****" (ski-rue) down your winder-stem (not a lock).
(Features a Ski-rue down crown & back case)
YOU can pretty much be assured that if the "stem" collar is malfunctioning (broken) the "water-proof" element is compromised (that's most likely the least of your troubles).
More importantly... if the STEM does not properly "tighten" it can
cause further damage against gears which MUST align with it... further it can come all the way out and be lost... Not an inexpensive part.
Best direction would be to get it serviced by an authorized agent.
TAG Heuer Aquaracer 500M Quartz Mens Watch WAJ1110 BA0870
TAG Heuer Aquaracer WAJ1110 BA0870
Jaxa style Suissetek XL Wrench Case Opener for Large Screwback Watches
Mar 30, 2016 | Tag Heuer Aquaracer Quartz WAJ1110.BA0871...
Tip
TAG HEUER Aquaracer quartz chronograph manual.
Follow this link and download original TAG HEUER Aquaracer quartz chronograph manual: http://www.tagheuer.com/the-collection/aquaracer/man/quartz-chronograph/index.lbl?w=CAF1110.BA0804
on Feb 09, 2010 | Watches
How do I set the alarm on model wau111a tag watch
  • Pull out the crown to the alarm setting position. The crown is located on the right side of the face of the watch. Pull the crown out until "AL", the alarm indicator, is shown on the watch. Depending upon the model of your Tag Heuer Aquaracer watch, you will either pull the crown out in the first or second position.
  • Select the hours and minuets for the alarm. Once your watch is in the alarm setting position, press the bottom right button on your watch. This will enable you to select the hours and minuets that you want to set the alarm for.
  • Set your alarm. To begin setting your alarm turn the crown clockwise until the desired hour or minutes are displayed on your Tag Heuer Aquaracer watch. If you happen to accidentally pass the alarm time, turn the crown counter-clockwise the get back to the desired alarm time.
  • Save your alarm. When you are ready to save your alarm, simply push in the crown. Once your alarm sounds, to silence it press any button on your Tag Heuer Aquaracer watch.
  • Nov 06, 2014 | Tag Heuer Link Watches
    I have an ct1115 tag heuer aquaracer chronograph and the caps to the buttons on the side fell off easy fix? you can push them with your nail the watch still works etc. the covers are gone
    The pushers sound like they have fallen off.This is quite a common problem.Take care as the watch wont be waterproof.The parts will need to be obtained from TAG and fitted by a watchmaker.Return the watch to an agent for them to attend to or find a watchmaker that can get TAG parts.
    www.rolexrepairs.co.uk are specialist watchmakers that could help.
    Regards
    Aug 04, 2010 | Tag Heuer Aquaracer Quartz Chronograph...
    I have an aquaracer automatic and it gains up to 6 - 10 minutes in a day. I have had it fixed before and it was fine for 12 months and now it has started again. Is this normal?
    All of the watches I have owned have run for many years without attention and when you buy one as expensive as yours, I would expect similar reliability.
    I suggest that you speak to the maker (or contact them via their web site "Tag Heuer.com") and discuss your problem with them.
    May 29, 2010 | Tag Heuer WAF2110.BA0806 Aquaracer...
    I HAVE A TAG HEUER AQUARACER ELECTRIC WATCH (BATTERY OPERATED) THAT HAS AN ALARM FUNCTION THAT I CANNOT SHUT OFF. IT GOES OFF EVERY DAY. HOW CAN I STOP THIS?
    I presume you no longer have the instructions, so I explored the Tag web site and they do not appear to offer an option to download instructions for your watch.
    The only thing I can suggest is that you go to your nearest dealer and ask for help. You can find out where your nearest dealer is by going to the TAG web site "tagheuer.com". select one of the watches and on the right of the screen you will find a menu which includes "find your nearest retailer", who will be able to help.
    Jan 12, 2010 | Tag Heuer 2000 Aquaracer Chronograph...
    My tag heuer aquaracer has a problem: the second hand stops and then speeds up really quickly for about 5 seconds. any idea why/how to fix it?
    Mar 11, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
    I am unable to return to the 0 crown Position - TAG-CAF2112
    The aquaracer has a 'screw-down' crown.  This means that the crown needs to be screwed in the reset it back to the 0 position.
    Jan 09, 2009 | Tag Heuer Aquaracer CAF2112.BA0809 Wrist...
    Watches Logo
    143 people viewed this question
    Top Tag Heuer Watches Experts
    Janelle Schoonover
    Janelle Schoonover
    Bruce Robin
    Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
