Question about Video Game Consoles & Games
Fan location on x52 - Video Game Consoles & Games
Posted by Charlie Potts on
X52 pro mouse function
How to bring up other e-mail that not opened a while: [email protected] ?
Jan 13, 2014 | Saitek X52 Pro Flight Control System Game...
How to replace keyboard onPhilips freevents X52
Well done! laptops are not easy to work with, so I congradulate you.
Mar 10, 2012 | Computers & Internet
I have a X52 pro. Throttle works fine, but the lights on the stick are constanly flashing and the stick doesn't work
if your X52 is less than 2 years old and you have the receipt, it's under warranty. Call Saitek and they will take it back and fix it (no charge). Mine is more than 2 years old so I am out of luck.
Jun 14, 2011 | Saitek X52 Flight Control System
I've downloaded the sst software and drivers for my X52 Flight Controller (NOT PRO) when I downloaded the profiles for the X52 Flight controller ALL of the profiles (pr0 format) say 'can't load file. I've...
According to the manual you can choose your profile by using the clutch function. Are the profiles that you downloaded of the same file type as the one you have been able to make from scratch?
Mar 19, 2011 | Saitek X52 Flight Control System
The official Saitek website only has the drivers for the X52 Pro and so though I only have the standard X52 (not the pro), I used the Pro driver and software. The profile editor does list the standard X52...
Saitek has drivers for the X52 on their website.
Here are some direct links.
XP 32bit: ftp://ftp.saitek.com/pub/software/full/Saitek_X52_Flight_Controller_SD6_32.exe
XP 64bit: ftp://ftp.saitek.com/pub/software/full/Saitek_X52_Flight_Controller_SD6_64.exe
If you need further help please let me know.
Hope it helps...
Sep 24, 2010 | Saitek X52 Flight Control System
Can i install 2 x52 units on bow and stern with
Yes you can...you would have to install a rotary switch between the displays and the transducer. You would also have to make sure to turn both displays off before switching the switch.
May 15, 2010 | Lowrance X52 Sonar Fishfinder Without...
I'm in Belgium fan of fsx with window 7 64bits with saitek x52 pilot 6.0.4.1(HID-USB) All the bitton are working except one : the twit (rudder). It makes a mouvement (kind of vibrations) around the the...
You should set this axis up first as a rudder in FSX settings, then calibrate it. Make sure you hav the latest drivers for it too. Make sure that Auto-rudder check box is unticked. I hope this helps, good luck
May 08, 2010 | Saitek X52 Flight Control System
The x-axis on my x52 flight control system doesn't work
try runing the install new hardware wizard then try and redownload all your drivers.
Jul 31, 2009 | Saitek X52 Flight Control System
Video Game Consoles & Games Logo
151 people viewed this question
Top Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Tom Chichester
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
