Question about Whirlpool Ovens
How to set temperature on whirlpool oven - Whirlpool Ovens
Posted by Dana on
2 Related Answers
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: Oven temperature increases 50' after original temperature is reac
What it needs is a new oven thermostat fitting, much cheaper solution than buying a new oven, it is a fairly straight forward repair, if you require more details let me know.
PLz rats my solution.
Thanks.
Posted on Jan 03, 2009
Malcolm Parsons
  • 250 Answers
SOURCE: My Whirlpool oven no longer heats to the set temperature.
Try to locate the thermostat sensor in the oven. It will be long about 5 inches, thin and cylindrical with a very thin wire coming from it. It should be bright and shiny. If it isn't buy some paint on oven cleaner from Lakeland and carefully remove the dirt. It may take a couple of goes. The sensor wire can be brittle so treat it with respect. Lakeland also do an oven temperature guage at a reasonable price if you need to check the temperature.
Posted on Dec 17, 2011
I have a Whirlpool drop in stove. I had food in the oven baking and all of a sudden the timer started going off. F-1 was displayed on the front of the stove. Can you tell mean what F-1 means?
F1 - Control Board Failure - Replace control board (clock).
F2 - Oven Temperature Is Too High - Check for welded contacts on bake and broil relays. ...
F3 - Open Oven Temperature Sensor (RTD) - Replace oven temperature sensor (RTD).
F4 - Shorted Oven Temperature Sensor (RTD) - Replace oven temperature sensor (RTD).
Whirlpool Google Search
Dec 15, 2016 | Whirlpool Ovens
On a whirlpool double oven, what does F2 error mean
F1 - Control Board Failure - Replace control board (clock). F2 - Oven Temperature Is Too High - Check for welded contacts on bake and broil relays. ... F3 - Open Oven Temperature Sensor Replace oven temperature sensor ( ). F4 - Shorted Oven Temperature Sensor ( - Replace oven temperature sensor
Nov 23, 2016 | Whirlpool Ovens
Whirlpool oven keeps heading up
What is the model number of your unit?
Jun 26, 2013 | Ovens
Can not raise temperature above 350
500 degrees farenheit is 260 degrees celcius (metric)
any chance the display is set for metric ?
Jun 28, 2012 | Whirlpool RBS305PDS Electric Single Oven
How do you recalibrate the oven temperature of a Whirlpool Accubake oven system
To do that;
  1. Press BAKE
  2. Select a temperature of 550 or highest temp on some models its 500
  3. Quickly (within 5-seconds of setting 550) press and hold the BAKE button approximately 5-15 seconds until "00" or the previously entered temperature adjustment is displayed.
    Pressing longer could cause an F0, F1 or F7 error to be displayed.
  4. Press the UP/DOWN arrow button or turn the set knob to change the oven temperature in 5° increments to a maximum of +/- 35°
  5. Press the CLEAR or OFF button to return to normal operation.
Gene
Aug 12, 2011 | Whirlpool Ovens
Whirlpool RF375PXDN oven will not heat to desired or set temperature
The problem with the oven temperature not matching the set temperature could be caused by a bad temperature sensor. You can check the resistance of the temperature sensor with a volt/ohm meter. Unplug the range and remove the temperature sensor from the inside of the oven.Here is a link to the part.
Jan 22, 2011 | Ovens
Thanks.
Jan 03, 2009 | Whirlpool RBS305PDS Electric Single Oven
Ovens Logo
89 people viewed this question
Top Whirlpool Ovens Experts
John Tripp
John Tripp
Marvin
Marvin
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
