Question about Akai Televison & Video
Akai mpk88 velocity....need to clean keybed. Need manual
Posted by Junior Basco on
How to replace rubber contact for cvp-307
HI
You need to dismantle the keyboard top, control panel, to get to the keybed.
Unplug the keybed and turn over.
You will see a circuit board the rubber contacts are below this.
Jan 04, 2018 • Music
How do I replace one key?
You will need to gain access to the keybed, remove screw from back of keybed the fix it to the base of the keyboard. Slide the keybed back making a gap of about 2cm at the front of the keybed.
Look at the back of the key towards where it pivots and you will see a small arrow, push something like a credit card between the keys at this point and the key will pop up, you can then slide forward releasing the key.
If you need more info please ask.
Need fuction key to turn on internet for gateway ne71b series
push function keyb and Wiffi keyb at the same time and this is all coment please !
Usb cable broken
Yes, you need to have midi in/out on your computer. Also you would need the optional AC adapter, which can be purchased separately from akai, in order to power your controller
When i turn on my Ensoniq SQ2 it either says Unexpected Event ID 144 or it boots up and plays random notes or when i play notes only a handfull work I looked at the service Bulliten about the problem but...
I'm guessing this is a main board problem. You can get the SQ-1 Service Manual (parts as well) here:
www.syntaur.com/ensoniq_manuals.html
The Service Manual is for the 61-note SQ-1, but that uses the same boards as the SQ-1, just a different keybed. I don't think this is a keybed problem. You can try unplugging the ribbon cable to the keybed from the main board, boot up, and see if you get the same crash. You may get a KEYBOARD CALIBRATION ERROR message, but you can ignore it; if it boots, the keys won't work, but at least you'll be able to see if you get that error message. If you still do, you know it's a main board problem and not anything to do with the keybed. And at that point, your only hope is to replace the main board.
Jan 28, 2011 • Music
Cannot play staccato, there is latency
Consider joining the forum here:http://www.patchmanmusic.com/WindControllerLinks.html It sounds like it is a velocity setting problem but the solution should be in your manual. It may also be a setting in the sound module you are using.
2answers
How do you clean a Lasko® High Velocity Blower Fan w/Remote
you need to dismantle the fan,
the top back pry off.
then you will see screws.
Televison & Video Logo
Top Akai Televison & Video Experts
Ekse
 Francisco Mauricio...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
