Hello Anonymous,
Here are 2 links to Harman ( Crown ) Support and Service Manual.
Crown suggests you call their tech support First to determine the need for repair.
Best of Luck,
JP
https://3e7777c294b9bcaa5486-bc95634e606bab3d0a267a5a7901c44d.ssl.cf2.rackcdn.com/product_documents/documents/2862_1433871166/XTi_Series_Service_Manual_original.pdf
https://www.crownaudio.com/en/support
Mine is the xti6002. Everything comes on but not sound.
Opened up no physical damage. Midway from the main board there's two boards standing upright from it. There is 1 green indicator on each of these boards. They flash for a period when switched on then stop off and no sound at all
SOURCE: i need the schematic for the crown amplifier
These are available for purchase from Crown. Generally they are not available on the web. Is there a specific problem that you are having?
Dan
SOURCE: crown xti 6000 cuts on
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be your output drivers- the MOSFETS/IC's fitted for both the channels, Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise like a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation. Thank you for using Fixya
You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the protect is off then check for short on the speakers.
