Question about Maytag Washing Machines
Not draining Maytag Neptune..Mah8700aww check pump .replaced and still won't drain
Posted by Frances E Tafoya on
Vernon Taylor
  • Maytag Master
  • 6,843 Answers
I am unfamiliar with your machine. It is usual the tub drain is at the lowest part of the tub and the pump is below. This means if there are no blockages, a weight of water is always present at the pump impeller so a simple pump can be used and no priming is necessary
Generally the arrangement of hoses, the drain and pump is so simple if there are no blockages and the pump is in good order and running, pumping is inevitable.
A blockage of the drain or of the outlet hose isn't unusual...
Posted on Jun 28, 2019
5 Related Answers
Rory O'Brien
  • 57 Answers
SOURCE: our maytag neptune mah8700aww front loader will
The drain pump os obviously either blocked or gone. Lie the drain hose on the ground to drain by gravity. Then have a look at the pump. This may need to be taken out as I'm not sure if there is a pump filter on this particular model. The door is designed to not open with water in the drum.
Posted on Dec 10, 2009
Anonymous
SOURCE: MAytag Neptune Drains Slow
How do you get to the stopper valvue?
Posted on Feb 28, 2010
fish8037
Roger Pierceall
  • 121 Answers
SOURCE: my maytag neptune mah8700aww is showing a nd code
I would first check the drain stand pipe to see if it is clogged in any way. You can watch it during a drain cycle, assuming your washer is draining, and see if it backs up in there. The next area I would check is the drain hose itself. Make sure it is not kinked, or blocked either. You can check for blocks by pulling the hose off and running a semi rigid object through it. A close hanger, straightened out will work most of the time. If all is clear, and you are not getting any other codes on your display, then the pump is the next thing to check.
Posted on Jul 12, 2010
FAV6800AWDIY
FAV6800A FAV9800A
  • 526 Answers
SOURCE: I have a Maytag Neptune
See this link for the Service Manual and a pic of Drain Pump/Drain Line on the right side of the machine. leaking at bottom of washer after it spins out not alot of water but a pain in the ****, how do you
You can place the machine in Service Mode once you have the Service Manual and turn on the drain pump thru console commands.
As I mention in the other post here on FIXYA you can only access the drain pump with the front cover removed.
If you place the machine in a Spin Only cycle will it complete the cycle?
If you can give a bit more detail on your troubleshooting maybe I can help.
Posted on Sep 05, 2011
kevin_getz
Kevin Getz
  • 1032 Answers
SOURCE: What's your problem?my maytag neptune washer is not draining
You might have a bad timer or drain pump.
Posted on May 27, 2012
My maytag neptune washer model MAH8700AWW want rinse or drain
Some thing is stuck in the pump or clogging the way, or it make have a drain circuit problem or a bad pump.
Jan 29, 2016 | Maytag Washing Machines
Maytag washer nd code
The control board is faulty and will need to be replaced. Here is the part to order and it comes with a 365 day, any part, any reason return policy.
Jun 23, 2013 | Maytag MAH8700A Front Load Washer
My Maytag Neptune MAH8700AWW washer when in the spin dry mode shuts down with a suds error?
Check your drain hose for kinks or blockages, check filter and pump for blockages, check wire harness connections to pump, pressure switch and CCU.
I machine will start- If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
Dec 29, 2012 | Maytag Washing Machines
MAYTAG NEPTUNE WON'T SPIN OR DRAIN
If it can't drain, it shouldn't spin. Pump blocked? Broken pump? Level sensor broken?
Sep 05, 2012 | Maytag MAH6700AWW Neptune Front-Load...
MAYTAG NEPTUNE FRT LD WASHER MAH8700AWW,NOT COMPLETELY THE SPINNING/DRAINING CYCLE,LEAVING CLOTHES VERY WET,WE SELECT SPIN CYCLE ALONE FOR EST. 9 MIN., THEN DRY, NEED A FIX - HAVE ONE ?
Check that the pump is operating properly. hold the drain hose over a bucket during pump/spin make sure its a reasonable output from the pump..If not remove and clean your filter, then readdress problem as before, if still no cure then check the pump blades are free.....If all is well and pumping okay then spin should be fine providing the motor is okay......Good Luck.....
Feb 16, 2011 | Maytag Washing Machines
Maytag Neptune Washer MAH8700AWW will not spin. It will fill, drain, tumble ect but will not spin. i tried a quick spin test and it sounds like it is trying to drain after all the water drains. I went...
You may have tried this, but check the door switch, and the pressure switch(water level switch) to see if either could be bad. both of those affect whether the washer spins or not.
Jun 12, 2010 | Maytag MAH6700AWW Neptune Front-Load...
My maytag neptune mah8700aww is showing a nd code do i need to replace my pump
Apr 09, 2010 | Maytag Neptune MAH5500B Front Load Washer
Our maytag neptune mah8700aww front loader will not drain and unlock the door. what do i do.
Dec 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH8700AWW Front load
I have a maytag neptune front loader (MAH8700AWW) unless I turn the water off @ the faucet the water continues to run into the washer after the load is done .How can I fix this.
Oct 20, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
71 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
