SOURCE: DVD's wont play - says wrong region but they are compatible
To change the Region code on your player, open Control Panel - System - Hardware - Device manager, and click on DVD/CD ROM drives, then right click on the DVD drive and click Properties then click on DVD Region.
You can enter a new region and it also shows you how many changes have been made.
NOTE you can make only 4 changes and the player will lock permanently on the 4th change.
If you want to play DVD from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece of software that allows you to play DVDs from any region. There are several available on the Internet but my favourite is DVD-Region Free
www.dvdidle.com/dvd-region-free.htm
SOURCE: Panasonic DVD VHS combo DMR-EZ48V will not play region 1 dvd
This is happening because your DVD is NOT all region, you need to change the Code.
en.wikipedia.org/wiki/DVD_region_code -
www.dvdexploder.com/ -
www.dvdexploder.com/multihacks.htm
www.allformp3.com/dvd-copy.../dvd-region-code-
free.htm -
www.dvd.reviewer.co.uk/info/multiregion/ -
Ok check those links out they will help you sort it.
SOURCE: unlock telefunken tel9800 dvd/vcr combo region
open tray
enter 0520, then press up, down, left, right (these are the keys around the ok/enter button)
a message will appear on the screen showing current region
press 0 and enter
it should now play any region
hope this helps
Angel
SOURCE: Region unlocking for a Sharp DV-NC80
I would like to play Area 1 DVDs on our Sharp DV-SL 1200 DVD player - please help us unlock it - Many Thanks
SOURCE: Is there a code to
In a word....NO.
Only DVD's themselves can be multi-region (region code 0).
I always advise on this site that you NEVER change the region code on your DVD player! Here is why....
To prevent DVD copy piracy, every DVD player from EVERY manufacturer allows (if it is allowed at all) only TWO changes to the region code. A third attempt to change the region code permanently locks the player and turns it into a paperweight.
If you happen to be the rare exception to the rule.... that you have moved to a new place that requires you to change the region code to view locally purchased DVD's, then by all means change it ONCE to be able to use your DVD player. Please remember that you can only change it one more time after that though! You will unfortunately not be able to watch DVD's that are from your old region.
