My cinemate 1 sr has no sound I have white solid light on speaker array and orange light on acoustimass module
Posted by Keith pardoe on
5 Related Answers
Anonymous
  • 70 Answers
SOURCE: Bose cinemate acoustimass module
try taking ones apart that have the rumbling and see if theres anything loose inside
Posted on Jan 21, 2008
kirtec auto
  • 1348 Answers
SOURCE: no sound from speakers ( lifestyle 20 )
remove the screws that hold the amplifier block to the speaker.the fuses are in the amplifier inside
Posted on Jun 14, 2009
ramminnathan
Nathaniel Berrios
  • 71 Answers
SOURCE: when i connect my aux to the computer from the
Hi, Im nathan.
The computer audio driver has to be setup correctly in order to the computer to emit the audio to the speakers. also the line for the aux jack check if it's not damaged.
Posted on Apr 29, 2010
gopakumarg43
  • 76416 Answers
SOURCE: What is the impedance of
Hello
The impedence of all speakers are [3.5 Ohms]. May connected upto [6Ohms] instead, provided the output will be a little less. Bass module cannot be connected with other sources. If you are intented to hear the music on an other room you can add speakers. For more detail, go to page [29] of its user manual, where all details and switching data are provided. All cannot be send by this window, as it will be out or capcity of this answer window. If you haven't its user manual with you now, send your email address to me by FixYa. I'll send a copy of it to you by return mail.OK.
Posted on Jun 02, 2011
ray gallant
  • 69201 Answers
SOURCE: could you repair a acoustimass module(cinemate gs series2)BOSE
sadly we here at fixya can only give advise . we are not a repair facility
Posted on Aug 08, 2016
Could you repair a acoustimass module(cinemate gs series2)BOSE
Aug 08, 2016 | Audio Players & Recorders
There is no sound
Confirm there is power in the wall socket and that the mains cable of the Acoustimass Module is OK,then check if the Boselink audio cable is inserted firmly into the zone1 output of the Media Center and the input of the Acoustimass Module.Turn the Acoustimass Module upside down and power the system,if led indicator blinks orange,the Acoustimass Module is faulty but if it blinks an intermittent but regular green light,the fault could be from the audio cable or Media Center.Only a qualified Bose Technician can handle this kind of fault
Feb 21, 2016 | Bose Lifestyle 48 System
My Bose cinemate 1 sound keeps cutting in and out. What is the most likely solution?
Chances are it has what is called a cold solder connection /or the audio ic heats up and cuts out
Oct 10, 2015 | Bose "CineMate 1 SR Digital Home Theater...
Bose cinemate troubleshooting
If the light on your control console just stays red and never changes, then the control module is probably bad. It's pretty common on the cinemate models.
Jun 06, 2013 | Audio Players & Recorders
Can the bass and treble be adjusted on the bose cinamate?
There is a bass adjustment knob on the acoustimass module(subwoffer). That is the only adjustment I am aware of at this time.
Nov 25, 2010 | Bose Cinemate Digital Home Theater System...
What is the color code for the stereo wires in an 08 land rover l
Battery BROWN/LIGHT GREEN(+)IGNITION SWITCH HARNESS
Ignition 1 WHITE (-) IGNITION SWITCH HARNESS
Accessory 1 WHITE/PINK (-) IGNITION SWITCH HARNESS
Starter 1 WHITE/RED (-) IGNITION SWITCH HARNESS
Tachometer WHITE (-) AT IGNITION COIL
Speed Sense YELLOW/GREEN (AC) AT MODULE UNDER PASSENGER SEAT
Parking Lights ORANGE/RED (-) AT MODULE UNDER PASSENGER SEAT
Brake Lights GREEN/BLUE (+) AT SWITCH ABOVE BRAKE PEDAL
Power Unlock BLACK (-) AT MOTOR IN DRIVERS DOOR
PowerLock BLUE (-) AT MOTOR IN DRIVERS DOOR
All Door Trigger VIOLET/GRAY (-) IN HARNESS TO RIGHT OF STEERING COLUMN
Trunk Trigger VIOLET/YELLOW (-) AT MODULE UNDER PASSENGER SEAT
Hood Trigger VIOLET/WHITE (-) AT MODULE UNDER PASSENGER SEAT
Headlights-Lo BLUE (-) AT MODULE UNDER PASSENGER SEAT
Wipers-Lo PINK/LIGHT GREEN(-) AT MODULE UNDER PASSENGER SEAT
Trnk Release WHITE (-) AT TRUNK RELEASE SWITCH
Battery RED/WHITE (+) RADIO HARNESS
Accesory YELLOW/RED (+) RADIO HARNESS
Ground TAN (-) RADIO HARNESS
Illumination GRAY/BLUE (+) RADIO HARNESS
LF Speaker (+) BLUE/WHITE
LF Speaker (-) TAN/WHITE
RF Speaker (+) RED
RF Speaker (-) TAN/RED
LR Speaker (+) RED/GREEN
LR Speaker (-) TAN/GREEN
RR Speaker (+) BLUE
RR Speaker (-) TAN/BLUE
Radio Security YES
(thats for 07 but shoe to what u need)
Aug 24, 2009 | Alpine Car Audio & Video
Left Channel Not Working.
Has it ever worked?
Try this - connect one pair of its speaker wires at a time and test it. Watch the polarity.
• Make sure all cube speaker arrays are connected to the proper terminals according to their
position in your room.
• Check to be sure all wires are connected to your surround receiver with the proper polarity
(+ to + and – to – wires). Incorrect wiring can result in a total loss of module output.
• Correct any wiring problems before you plug in your receiver and turn it on.
How do you know the receiver's Left channel isn't the fault? Sounds like a source issue.
Jan 04, 2009 | Bose Acoustimass 16 Speaker
Jan 21, 2008 | Bose Cinemate Digital Home Theater System...
21 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
