Question about Husqvarna Sewing Machines
My husqvarna huskylock s25 won't stop running. I turned it off and turned it back on and it immediately started running and won't stop.
Posted by Gi'Anna Cheairs on
harrisandreson
    Problem Solver:
  • 10 Answers
If the needles are in right, and it still won't form a stitch, then you'll need to take it to
Posted on Jun 27, 2019
Testimonial: "This doesn't have anything to do with forming a stitch. The machine is running and won't stop. I need it to stop running first before I can check anything."
2 Related Answers
Tally Girl
Tally Girl
  • 1134 Answers
SOURCE: I have a new Viking
How do you mean the tension are off? A serger should have 3 or 4 tension knobs (although yours looks like it is push button digital settings) and generally from new these will produce a standard stitch when all are set to 5. Are you sure that you've got the thread pulled into the tension discs fully? Check each one by pulling on the thread below the tension disc and feel for resistance, if the thread pulls very easily, then recheck and thread again.
Have you got the thread aerial raised up to the full height? Remember also to put the plastic cone holders under the thread cones as you want the cone to stay still and the thread to feed off it - it does this very fast, sergers sew at 1500 stitches per minute so the thread streams off the cones very quickly.
Using a serger is quite different to a sewing machine and your model looks like its one of the later computerised ones with multiple stitch options including coverstitch. I'd suggest that you go back to your dealer and ask to spend time with them for a demo, thread up in front of them for pointers or take a class to familiarise yourself fully with the machine. Then go home again, break out the manual, and go through threading up from scratch several times until you've got it off pat. Remember to thread top looper, bottom looper, left needle, right needle in this sequence always, then pull all threads under the foot, lower pressure foot and serge off a short chain. To change colour thread, you can always cut and knot on new threads, turn tension down and pull through the loopers, but you've got to thread the needles fresh each time you change colour.
There is some good videos on You-tube, Nancy Zieman has a several and she's also written several books on using a serger and obviously the manual is first point of reference.
Each fabric will behave differently so for each new fabric, you will need to adjust tensions and move the blade to get it stitch and just encasing the cut edge at a suitable width. To work out how it should look, break out some ready to wear garments and have a look at those seams, then test and practice with your machine to get a similar stitch. Always test serge two thickenesses if you are going to use it to construct your garments and pull open from the right side to ensure the needle thread is tight enough so the seams don't pull open under wear.
Good idea to keep your test seam samples in a notebook and write down the settings you used for reference next time. I have to say, I've done flatlock with silky decorative thread once in 19 years - but I do know how to set up the machine for this. However, rolled hem with wooly thread is very useful and I often use this to edge hems. I'm envious of your coverstitch option, this is great for hemming and necklines and is something early sergers didnt do.
Just checked out this model on an Ebay vendor's site and it mentions a training DVD, you've got several different stitch types to master with this machine so there will be some learning and practice involved to get it right. Good luck - I hope this is of some help but I'd be visiting the dealer for specific help if you can.
Posted on Apr 30, 2011
radcal
  • 196 Answers
SOURCE: Husqvarna huskylock 580 Overlocker_Instructions
I know of no source for manual. Best to find someone that knows how and have them teach you. None of the youtube videos are very close to your model.
Posted on Oct 26, 2011
Lcd screen wont turn on my huskylock s25
if you are the original owner of the machine, take it to an authorized Viking repair dealer with proof of purchase. it may be under warranty.
Apr 08, 2014 | Husqvarna Sewing Machines
Touch screen for the Husqvarna Huskylock s25 will not respond when touched. Is there a reset for the problem?
Turning it off for a few minutes and then turning it back on usually will reset. However, the problem could be a computer board that is going.
Oct 06, 2013 | Sewing Machines
My Huskylock 936 won't sew. I was sewing yesterday, 4 thread overlock. I finished a seam, cut the thread, proceeded to sew another seam. I put my foot on the pedal..and nothing.If I turn the machi
Good evening madam
It sounds like there is something wrong with the electrical system in your sewing machine. You can check the power and connections.
good luck
Kolbrun
Feb 26, 2012 | Husqvarna Huskylock Computerized 936
My serger won't start. Motor is running but won't turn. Also wheel wont turn
Hi, On most of these newer machines they have a clutch that you engage to fill the bobins.
Please make sure that the clutch is disengaged for normal use. If this is all OK see that belt
is attached on motor.
Jun 05, 2011 | Husqvarna Huskylock Computerized 905
Huskylock 936 error code
This will also occur if the "needles" and "loopers" lock up as though threads are tangled and binding the machine. If needles and loopers move freely when manually turning the handwheel counter clockwise, you probably need to take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Nov 28, 2009 | Husqvarna Huskylock Computerized 936
Husqvarna Huskylock 550D manual
I have a Huskylock 550d overlocker and the manual. Where do you live? email me on [email protected]
regards Barb
Sep 16, 2009 | Husqvarna Sewing Machines
Huskylock 936 Motherboard Replacement
Any qualified Husqvarna technician should be able to order one for you. I would recommend that you have it installed to save yourself the heartache/break.
A main board, if I am looking at the correct one on the list, will run about $240.
Aug 15, 2009 | Husqvarna Huskylock Computerized 936
Need to find compatible presser feet for Huskylock 700
Sorry, not familiar with the Huskylock 700. Suggest you visit authorized husqvarna viking dealer. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Feb 28, 2009 | Husqvarna Huskylock Computerized 905
Sewing Machines Logo
43 people viewed this question
Top Husqvarna Sewing Machines Experts
radcal
Douglas Plant
Douglas Plant
sewcrazyshan
Level 1 Expert
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
