Question about Sony MHC-GX450 CD Shelf System
I put it a cd in play and it says on the display no cd.
Posted by aron285 on
Anonymous
    Problem Solver:
  • 6 Answers
If it does it with all cd's, then its likely the optical coupler in the unit is tired or not functioning.
This is the most expensive component and is most likely as cheap to replace the unit
Posted on Aug 16, 2009
2answers
How do I set free play on my rowe laser100
Hi you put on service , then you enter 84 then you put the number of credit you want by example 9999 and you press popular and you put back to normal mode
Kdc-mp
put a cd cleaner in your cd player see if that helps.
1helpful
Denon CD deck
This unit needs a service visit. It may be a common problem with that model but to me it sound like a power supply issue as when you play a disc more power is used to rotate motors and move the sled. This is indicating to you that it is in a weakened condition and will soon fail more significantly. The problem may be as little as a solder joint or a defective Filter capacitor which is common in some models of equipment.
KD-HDR40 will not play any CDs, only displays a "CD reading" message.
Sounds like CD mechanism failure. Did some sticker or anything went inside? Any way, need service.
Technics SL-MC60 error message: "Take out"
Hello
If a disc has been put in the slot of the disc in play, Remove the disc, whose number is displayed, and press stop button.
Because of light or noise, the changer has detected a disc in the lot of the disc being played, even though it is empty. Check whether there is a disc in the displayed slot. With front panel closed, hold down "STOP " button for atl least four seconds or more.
2answers
I've had my jukebox for 6 years and the free play ran out. I forgot the code its a rowe cd 100 commerical
it should have a free credit button on thecircuit board they usually black or
red just press several times
2helpful
When i put a cd in to play, we cant get the words to show on digital screen??
You MUST use a special Karaoke CD disk to show lyrics on the screen. Plain music CD's will play music but NOT display the lyrics. Karaoke disks can be expensive... so shop online for Karaoke CD's. Some music stores, including Costco and other warehouses sell some Karaoke disks, but they are usually in a very small section of the displays.
3helpful
4answers
I have an ami Rowe Model Laserstar CD100-F Jukebox that I purchased at a fundraiser. It works great but it has somehow switched from the mode where it plays without inserting $ to only playing when you put...
most all "early models: Rowe CD 100 Laserstar's
Put the slide switch in service position. Go past the errors (if any) by pressing Popular and Reset simultaneously then enter "55" the display should say "free play off" then hold down the reset key and push 9. This will toggle between "off" and "on" Toggle until the display indicates free play "on", then release the reset key and press the popular button. Put the service switch back in to the play position, The display should say "FP" however not all models display it exactly the same. If your computer's battery is good this setting will be retained. If you have to load the factory defaults for any reason OR another problem (dead battery) is causing the factory defaults to be loaded when you power on, this free play setting will be reset to "off" after power is interrupted.
Plays radio fine put cd in and cd plays but no sound
if the track numbers are displayed and counting then we can assume the cd is playing. and the sound/audio decoder is defective. it is usually a large integrated chip.(VLSI).
CDs wont play
archo69..big chance your laser is on its way out..it also can be the bottom lense is dirty to ,but this requires your stereo to be removed .dismantled and cleaned manually
Sony MHC-GX450 CD Shelf System Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
 Francisco Mauricio...
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
