Question about Uniden Lands Phones
..have accidentally pressed something and now can't get callsHow to unblock number on my Uniden Xdect 8155 series
Posted by Gwen Abzatz on
Cathann Smith
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 42 Answers
Usually you can press block calls again it will give you your list of numbers and you can usually unblock from there. If nothing helps call Uniden customer service and they will help you.
Posted on Jul 01, 2019
1 Related Answer
Thomas Smithbrother
  • 3698 Answers
SOURCE: uniden xdect 8155 not recording and playing back message
telephones.att.com/product-support
Posted on Jun 30, 2014
We have just purchased a Uniden Xdect 8355 series telephone. When the phone rings we get a message telling us who the call is from, how do we get rid of it?
Do you want to delete entries from the Caller ID list? This records the numbers of the last 50 incoming calls. You can't delete the entire list at once. However, you can delete one entry at a time. Press CID on one handset or base with the entire system in standby (no active calls). The CID button is to the right of the Menu/Select button. Press the Up/Down arrows (above and below Menu/Select) to select one call. Press Menu/Select to get the details of that call. If you don't see list with Delete Entry, Add to PB, and Add Call Block, press Menu/Select again. Select the Delete Entry line and press Menu/Select. Select Yes and then Menu/Select again if prompted to confirm the deletion.
When you are done, press End/Clear to exit the menu system. You'll find these directions on page 30 (page 31 of the pdf) of the manual. Uniden has the manual here: https://www.uniden.com.au/RESOURCES_MAIN/pdfs/XDECT_8355_OM.pdf .
I hope this helps.
May 18, 2017 | Uniden Lands Phones
How do you register a uniden Elite 9135 handset to a Uniden 8155 base or vis versa?
probably don't
the base and the hand set have to both be the same so the handset will be a 8155
contact uniden teck advice for the answer
Mar 24, 2017 | Uniden Lands Phones
How do I setup a Uniden Dect 5.8Ghz 8155+2 phone
Uniden XDECT 8155 + 2 Questions & Answers ...
www.productreview.com.au > ... > Uniden > Uniden XDECT 81xx Series
Uniden XDECT 8155 + 2: 25 questions and 38 answers on Australia's largest opinion ...and select Handset Setup or Base Setup. ... If you have a 2.4 ghz or 5.8 ghz modelphone use web address below. .... Uniden Premium DECT 31xx Series.
Nov 23, 2015 | Uniden Lands Phones
My uniden xdect sse25 cordless doesn't ring for long enough before diverting to the answer machine I have mobility problems how can i extend the length of the ring
From the handset, press Select/Menu and then press the down arrow to get to Ans Setup. Press Select again. Go down to Ring Time. Then select the number of rings (6, 9, 12 or Toll Saver (TS)). Press Select then press Flash/Exit to exit the menu system. Toll Saver picks up after 2 rings if you have new messages or 4 rings if you don't. This lets you hang up before the answering system picks up if you are using the remote phone access feature.
Note: if you have Voice Mail from your telephone provider, you need to set that to a longer number of rings separately. Consult with your phone company on that option.
The manual for the XDECT SSE25 is available from Uniden here: http://www.uniden.com.au/RESOURCES_MAIN/pdfs/XDECT_SSE25_OM.pdf . See page 19 (23 of the PDF). You will need Adobe Reader to access the manual.
I hope this helps.
Jan 25, 2013 | Uniden Cordless Phone
Lands Phones Logo
124 people viewed this question
Top Uniden Lands Phones Experts
k24674
Marvin
Marvin
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
