Question about Dynex Televison & Video
I turn off my dynex tv,and a few seconds later it turns itself right back on,keeps doing this until I hurry and remove a battery from the remote,before it turns itself back on.Now Tv will not turn on
Do I need a new tv remote?
Posted by Josh Thompson on
David Spradling
    Top Expert:
  • Dynex Master
  • 11,272 Answers
Check for stuck button on remote if ok bad control board
Posted on May 23, 2020
5 Related Answers
Anonymous
SOURCE: TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Posted on Sep 14, 2008
Anonymous
SOURCE: Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Posted on Oct 21, 2008
Anonymous
SOURCE: Insignia TV
Ok, I had the exact same problem last summer, and Kevellen told me of a problem that Insignia tv's have: the circuit that controls whether the tv is off or on is messed up, and it can be fixed, but its not cheap.
http://www.fixya.com/support/t924975-wierdness_tv
Anyway, if the t.v. is still under warranty, I would say return it to the store and see if you cant get a new one, and from what I researched online after this incident, I will not buy an Insignia aver again.
hope this helps,
-Steve
Posted on Jan 04, 2009
Anonymous
  • 3 Answers
SOURCE: I have a 32" HD AKAI TV that keeps turning itself off
If the service shops didn't charge people $200 to fix this I would not post.. But since they do - here's the $8 fix.
If you are electronically inclined, replace the three 1000uf 16v electrolytic capacitors in the power supply board located above the power switch. They are likely bulging out at the top and failed. They are the three in a row at the top - center of the board, located between the two black heat sinks. Make sure you get caps rated for 105c degrees! I recommend replacing them with 1000uf 25v caps. 35v caps will work but might be a tight fit as they are larger diameter.
Should cost you about $8 for the parts shipped. You can get them from partsexpress or digikey or any good local electronics store. Your local radio shack may have them but they won'y be 105c and thus may not last long.
Not handy, ask around, there is usually some electronic tweaker guy around that will install them for a few bucks.
This has solved the turns on / then off problem every time in the 3 I've done.
Posted on Jan 11, 2009
Anonymous
SOURCE: 52" RCA big screen tv turns on and few seconds turns off by itsel
if you heard a hissing or like static sound your board probably has a hole in it now. the board on the left side with the flyback fransformer. the hole is from where a prong has come loose an is arking over an it burns the board the ark is the sound you heard.
Posted on Jan 30, 2010
Need sansui 076k0ut011 led tv remote codes to program an rca tv
reset sansui tv remote control 076k0ut011 Questions ... - Fixya
www.fixya.com > Forum > Tags
...your help in advance. need code for a one for all URC-2060B06 sansui tv try these ... ...sansui tv with a RCA 704 remote control I have sansui tv and a RCA 704 remote ... URC-3021 Remote Control: How do i program this remote to a sansui tv? ... TV Remote Controls Sansui Remote eBay NEW Orion Sansui JVC LED TV ...
reset sansui tv remote control 076k0ut011 Flat Panel ... - Fixya
www.fixya.com > ... > Tags > reset sansui tv remote control 076k0ut011
Flat Panel Televisions reset sansui tv remote control 076k0ut011 questions and answers. ... ...sansui tv to program rca remote to it model # HDLCD1955C need tv code for this model ... Question about Contex 39-inch 1080p LED TV LE39D3.
Original Sansui - Orion TV Remote Control 076K0UT011 ...
? 1:00
https://www.youtube.com/watch?v=mPbRsUI0xnk
Dec 21, 2012 - Uploaded by ElectronicAdventure
Original Sansui - Orion TV Remote Control 076K0UT011 - Save $5 with ... have the New Original Remote ...
[PDF]Operating Instructions For 4-Function Cable
Dec 16, 2015 | RCA Televison & Video
My TV does not respond to the remote. I can only turn the tv on and regulate the sound by pushing the bottons on the TV
IS it a universal remote? If yes, remove the battery, wait for 10 seconds or more, fix the battery back in and re-register the remote with the TV by entering the code. But it the remote works with the TV without code, try again. If this doesn't fix the problem, please read further.
Try the remote with new batteries, ff new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
I hope the above makes sense to you.....
Good luck.
Apr 04, 2011 | Televison & Video
IR Remote Control Remote Control: how do I set up my remote with a brand new insigni...
If you have a universal remote control, programming details are included in the remote manual. If you need to program the Insignia TV remote, details are also in the TV owner's manual. If you need a copy of the manual for your TV, a downloadable version can be found at InsigniaProducts.com by searching for your TV model number and clicking Support.
May 17, 2010 | DISH Network IR Remote Control
I NEED THE CODES
each remote has a new setup.normarlly oo4 does it.
Mar 02, 2009 | Universal Remote Control 10694 Remote...
New settings on tv remotes
Hello Slffvo:
Here are a few web sites that may help you out.
http://www.hifi-remote.com/ofa/devices-tv.shtml
http://www.universal-remote.net/philipsmagnavox.html
Aug 14, 2008 | Philips Magnavox Learning Universal Remote
Sky remote code
You will need to go to Sky's website and order a new remote if this doesn't work.
Press tv on the remote
press and hold Select and red until the remote LED blinks twice
type in 0 0 6 0
press power button on the remote, if the tv goes off press select and it should control all the tv functions.
if the tv does not go off press tv then power buttons on the remote and keep doing this until the tv goes off, then press select once the tv goes off.
Like I said earlier, if this doesn't work you will need to order a new/replacement remote via Sky's website then put the code listed above in.
Jul 18, 2008 | RCA RCR660 Remote Control
Televison & Video Logo
65 people viewed this question
Top Dynex Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
