Question about Car Audio & Video
I have the bunker hill 95914 wires are green yellow black and white New wires are red green black and yellow how do I hook up?
Posted by Jaybo Sykes on
5 Related Answers
Anonymous
  • 243 Answers
SOURCE: MOTHERBOARD WIRING
Instructions should be in the manual found here
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=302
They sound like they are for your from usb posts on case...but thats just a gues :)
Hope that sorts it for you?
Posted on Dec 30, 2007
paul proctor
  • 4102 Answers
SOURCE: re sent wire diagram gat all messed up
Hi
have we spoke before in previous post?
the red can go to any 12v live peramanent such as wire to clock or other item that has power with ignition off and the same with the yellow if your putting these to the same permanent live say from clock you can join these to together red/yellow to red on clock
the black can go to any metal or neg wire.
This should then have your device working the only problem im looking at for you now is the pink wire as this stops you using the device whilst driving as it goes to handbrake but i need to find out if its live or negative.
You could just wire the red/yellow to live and black to earth then see if it switches on and works if not then let me know and ill see about the pink wire ok
Makes sure you use inline fuses on the live wires so as not to short the device out.
Make sure you know what is permanent live to put the yellow/red wire to.
It doesnt need to be ignition it only says this so you cant use it with ignition off but you can wire it into any live feed from clock or switches so its up to you what to wire it to its just the pink wire im concerned about.
PINK: does it tell you to put it to live or earth on handbrake switch?
let me know ok
Posted on Apr 21, 2008
Anonymous
  • 379 Answers
SOURCE: 1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
cheers
djmac62 is also an excellent answer
Posted on Jan 10, 2009
Anonymous
SOURCE: trying to hook up a dimmer switch it has a red
For a single-pole installation:
1. Connect the 2 white wires together (one from the source and the other to/from the light fixture) - 2 wires
2. Connect the black wire from the source to the black wire on the dimmer switch - 2 wires
3. Connect the black wire to/from the light fixture to the red wire on the dimmer switch - 2 wires
4. Connect the ground wires - 3 wires
Posted on Mar 30, 2009
bobwyman85444
Bob Wyman
SOURCE: can the bunker hill security color security camera
95914 is : Green is voltage (12vdc), yellow is video, black is common ground to voltage source and camera-to-monitor, white is audio.
Posted on Mar 25, 2014
I have a Bunker Hill security camera 62468 wires been cut have 2 red 2 black and 1 yellow how do I hook it back up
here is the link to the manual. you might be able to find a phone number of their tech support to resolve your issue.
Sep 13, 2017 | Bunker Hill Security Home Security
Rca wires on bunker hill security cam are red black white and yelliw need a diagram to help rewiring
black is power,yellow is video,red and white are audio left and right
May 31, 2015 | Cars & Trucks
I'm trying to hook up a Kenwood kdc x492 to a 96
Battery is yellow
Accessory is white/red
Ground is black
Illumination is red/black
Power antenna is yellow/white
LF speaker +blue/green - grey/black
RF speaker +red/green - brown/black
LR speaker +blue/yellow -grey/white
RR speaker+red/yellow -brown/white
Feb 11, 2013 | Car Audio & Video
Cut wires on bunkhill weatherproof security camera#95914
My bunker hill has a black, white, yellow and green. I am confused with the white. Help
Oct 17, 2012 | Home Security
Need to find out what color wires to use to fix my enforcer infared security camera the wires got cut. Color wire for splicing the wire on.
I have a small color security camera with infrared that is intact. This camera is an exclusive Harbor Freight Tools distributed product. I have attached pics of it, the last pic of the small connecting box looking into the connection starting from left to right are 4 wires 1=yellow 2=blue 3=orange 4=white. I hope this is of some help to you. I unfortunately don't have the other end of the connector and am looking for pinouts to hard wire it to my monitor. If some one has this info please pass it on to my email zimpmd at aol. Thank You Michael Zimpleman
Jun 05, 2011 | Cameras
Replacing front turn signal socket on 1990 dodge shadow
Okay. Hook black to black.
Green to green with white stripe.
Yellow to red with white stripe.
That should work. Nothing is going to blow up if it's wrong. It just won't work.
May 15, 2009 | 1990 Dodge Shadow
Car Audio & Video Logo
102 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
