Coffee Makers & Espresso Machines Logo
Karen Ervin Posted on Jun 27, 2019
My BUNN "My Cafe" model MCU spits grounds into cup when using K cups. What am I doing wrong?
5 Related Answers
Anonymous
  • 1214 Answers
  • Posted on Jan 20, 2009
SOURCE: I PUT IN 10 CUPS
Is the cup size you are using to measure what comes out of the coffee maker the same as the cup size that you are using to measure what your putting into the coffee maker?
Anonymous
  • Posted on May 19, 2009
SOURCE: Keurig machine releasing coffee grounds on top of K cups
I have the same problem but if you take a paper towel and clean the grounds from the top each time it helps. Cleaning around the little point that pierces the cup. It helps but doesn't completely eliminate the problem.
EsWorld
Ernest R
  • 1618 Answers
  • Posted on Jul 24, 2009
SOURCE: Set flow amount on Bunn STF 35
Remove the top panel and look for the yellow float, this controls the amount of water brewed, to adjust remove some of the washers on the float and test until you get the amount needed.
Anonymous
  • 147 Answers
  • Posted on Oct 26, 2009
SOURCE: i have a bunn coffe maker, 10 cup that has a top
How old and have your ran vinegar water mixture to clean teh coffee maker? I woould run 1 part vinegar to one part water to clean coffee makers 2 -3 times a year. Here's a vinegar cleaning link.
http://ezinearticles.com/?How-To-Clean-A-Coffee-Maker&id=57769
Anonymous
  • 40 Answers
  • Posted on Jan 04, 2010
SOURCE: Coffee grounds overflow out of basket into top of coffee pot.
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine nor too course. (See instruction manual.)
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz. Note: Some coffee makers define as little as 5 oz as a cup.
4. Make sure the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. Clean your machine with vinegar or as instructed by your user manual at least three times per year, more if your water supply is hard. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket as the water runs through the grinds.
9. Ensure that the coffee machine is sitting level on the counter.
After brewing with a Bunn MCU, it does not fully use all of the water; some remains in the coffee pod. It does this with all textures of coffee grounds. It makes cleanup a mess. Any ideas? Thanks!
First, Though I have worked on many Bunn commercial systems. I'm not quite familiar with the newer MCU though I've worked on similar single cup home systems.
* Most single up systems like the Cup/Pod/Capsule usually have a air flusher that pushes all the water out of the brewer to extract all the flavor and prevent old liquids left in unit.
* If your still dripping, have wet pods/capsules/cups, then it sounds like the air pump is not turning on or not working properly. Bad pump could be a cracked or loose hose as the pumps don't really wear out as it's only air (hopefully clean air, no dust). Call for service.
* The brew cycle might not be completing thus not continuing on to the next step which is to pump air in. Brew sensor or timer out. call for service
* Computer is out or fried (especially after an electrical storm). Call for service.
* Finally, most of these home units do not have serviceable parts. Most take at least an hour to service. So if your not in the warranty period it may not be worth fixing. But be sure to call your service provider or MFR for advice.
Aloha! ukeboy57
WHY HAS MY CAFE STOPPED WORKING? IT DOESNT DRIP COFFEE INTO CUP.
Sounds like your machine is congested. Consider cleaning out the nozzle or the filter.
How do i clean my cafe before first time use.
Add about a half cup of white vinegar to the water an run it through
the maker about three times.After that use fresh water about three times. should be cleaned out .
1helpful
BUNN MY CAFE BAD TAST WITH COFFE OR HOT COCO
Try really cleaning the basket that the water and coffee or cocao goes into. If you don't really clean it well, it will have the taste of the last thing brewed mixed in with the new brew. Coffee followed by coffee should not be a problem, but coffee followed by cocao will give the cocao a coffee taste, and visa versa.
Coffee maker is making very mild coffee. Looks more like tea. ANything that can be done?
You may need to add more grounds. We use 1/2 cup coffee grounds for our 10-cup machine, and it comes out perfect every time. If you prefer to grind your own beans, use 1/2 cup of beans, then grind.
If i try to make more than 6 or 8 cups in my 10 cup bunn coffemaker. The coffee grounds overflow . This is a new coffee maker and we find a mess almost every time we make a pot. We have alwats used bunn...
This can occur with the use of finer ground coffee or use of soft water, filtered water, or bottled water. If you will call 800-352-2866 with the model and date code, we can send you a flow restrictor sprayhead which will alleviate this problem.
When I put in, 6 cups of water, if the 10 cup Bunn coffee maker after it has sat overnight, it only expels about 4 - 4.5 cups. I don't think it can all be evaporating or being absorbed in the grounds can...
look for water leaks around pot. Otherwise do a daytime brew to compare your difference between the amount poured in and what comes out. Please note that less water should mean using less ground coffee. Suggest 1 heaping table spoon per brewed cup.
Top Bunn Coffee Makers & Espresso Machines Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
