Question about Stoves Ovens
How to repair stoves built in oven. Model number 444440827
Sometimes these controls are custom and need to obtain an exact fit OWM replacment (rather than a generic part.)
If your in the UK, try contacting
B Grade Domestics,
1, Armscroft Road, Barnwood,
Gloucester. GL2 0SQ,
UKSupport: 01452341595E
mail: [email protected]
Posted on Jun 26, 2019
SOURCE: Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Posted on Dec 14, 2007
SOURCE: GE Model #JBP76GS1WW Oven Control Knob
First contact GE directly, they will send you replacements for half that price and you can do the labor yourself. 1-877-959-8688
Posted on Feb 01, 2009
SOURCE: Necht model 720 built in electric oven. Fan
If the oven fan is working o/k, thenyou need to replace the fan oven element.
Please rate my solution.
Thanks.
Posted on Sep 16, 2009
SOURCE: I need six knobs for a 1950 Frigidaire model RM-45
I have the same model stove for sale. here is my number 678-644-2161 samantha
Posted on Mar 29, 2010
SOURCE: element wires fell behind oven
I just had the same problem with our Electrolux wall oven. I don't expect you are still having problems 3 years later, but thought I would post for the benefit of anyone else with this issue.
Firstly, turn your power off. I then had to unscrew two screws on each side of the oven door which allowed the oven shell to come forward. You should then see the power cord which you can remove from the powerpoint. If your oven is hard-wired in, then I would definitely call an electrician.
Once I removed the oven, I placed it on the floor and unscrewed a few screws that held the top and back casing on. After removing the casing, you can see the wiring and you just need to push the fallen wire back through.
Before you put the casing back on, you could replace your element just in case the wire falls through again.
Posted on Dec 04, 2010
