Question about KitchenAid Dishwashers
What is the problem with a kitchenaid dishwasher. It will start a wash but abort shortly and the start/resume button will flash.
5 Related Answers
catriver
Ron Marek
  • 878 Answers
SOURCE: Dishwasher's "Pot-n-Pans" light flashing
ga, behind the toe panel on the bottom there should be a tech sheet explaining how to put the dishwasher in the test mode. See if you can enter the test mode. If you can't, you probably have a stuck or shorted keypad. Catriver...post back
Posted on Mar 03, 2007
reg501
Richard
  • 413 Answers
SOURCE: My KitchenAid dishwasher model KUDM01TJBS0
The blinking buttons indicate the buttons are bad. The console will have to be replaced.
Posted on May 29, 2008
Anonymous
SOURCE: Kitchenaid Dishwasher door wont latch
I have a brand new whisper quiet dishwasher model kudk02crbs4 I hook everthing up but the door does not lock what is worng I have no clue what wrong
Posted on Jun 12, 2009
erpaalai
Eric Duda
  • 999 Answers
SOURCE: kitchenaid KUDS25SH
Hold the button down until it beeps and the light goes off. Eric
Posted on Sep 03, 2009
Adrian Scovell
  • 128 Answers
SOURCE: Kitchenaid dishwasher will not turn on or drain
Float valve is jammed.
Look inside the machine on the floor will be a small float valve. Looks like a small upside down cup. Lift it and clear anything from underneath.
The valve is a safety feature to stop the machine from over filling. If anything gets under the valve it will jam open and stop the machine.
Not working?
Check for a clog internal or external.
Scoop as much water our as you can. Open the cover on the floor of the machine. Usually just turns and lifts out or snaps out some are screwed in. Take your time and try not to force anything. Look for a clog there.
Check for clog in the drain. The dishwasher will connect to the drain under your sink and run either directly to the drain or into your disposal unit. Remove open the connections and look for a clog. Clear if necessary.
Not the clog?
Water is pumped out by the machine via an internal pump located under the base. If it fails the water will collect until it trips the float valve. First scoop out all the water from the machine and run it again. If water comes in and it runs to the point it fills again and trips the float then either the pump or timer is faulty.
Pump check.
Remove the machine. It will be held in place by screws directly into the counter top. You may have to lower it to get it out. The front feet turn with a wrench to lower.
Turn off the water supply. Run the unit again until you get to the drain cycle.
Connect a test light or voltage tester to the terminals at the pump. Check for voltage at the pump. If you have voltage replace the pump. If no voltage the timer is faulty.
Timer problem?
Some can be replaced as a unit others are integral to the control panel. Turn style can be replaced. Touch control can not.
For more help go to my more detailed tip "Dishwasher will not run. DW101 how to fix". Or click on my profile and you will find the link there.
Hope this helped you. Please take the time to rate this tip.
Thanks,
Adrian
Posted on Mar 17, 2010
How do I fix a flashing Start/Resume light on a Kenmore Elite dishwasher model 665.13793K601?
These dishwashers are known to accumulate moisture in the keypad and then short. The solution that I have seen is to replace the keypad...It is possible that all of your issues with this dishwasher could point back to the keypad. After spending $$$ on the circuit boards, do you want to throw and additional $135 for a keypad? or replace the whole unit? Food for thought. Here is a link for you:
http://www.repairclinic.com/PartDetail/Control-Panel/8572855/1180767?modelNumber=665.13793K601?RCAID=1000065
May 22, 2014 | Kenmore Dishwashers
Kitchenaid dishwasher KUDS01DJ Rinse only light is flashing. control panel is frozen with only rinse only light flashing. does not respond to pressing of any buttons. I flipped the breaker switch,...
Ok, Turn breaker off at breaker panel. Just off then on. The rinse only light should be on.....not flashing. Now press the start button first and hold; then press the cancel button. That should cancel all lights. Then press wash button then start. If the light is still flashing after you turn off breaker....you might have a bigger problem. May need new control panel.
Aug 19, 2011 | KitchenAid KUDS01DJ - Multiple Color...
THE FOLLOWING BUTTONS WERE DEPRESSED.......NORMAL WASH, HEATED DRY AND LOCK ON......ALL THESE BUTTONS HAVE A STEADY LITE.....THE START/RESUME BUTTON LITE IS FLASHING. IHAVE HELD THE START/RESUME BUTTON...
Hi
Press and hold the NORMAL WASH-HEATED DRY button simultaneously & repeat this sequence for 5 times...this will reset the control. Hope this helps...please post back for further assistance.
Daniel
Jan 21, 2011 | Kenmore 24 in. 16039 Built-in Dishwasher
Wash cycle does not start. I push the normal wash (or any other cycle) button and a tiny amount of water flows. If I leave it alone, eventually, several lights start flashing. I have tried pressing the...
Either the hose is clogged at the entry point to the dishwasher or the solenoid vlave is bad...
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble
No Water entering Dishwasher
heatman101
Dec 21, 2010 | Dishwashers
Kitchenaid dishwasher does not run; start/resume light keeps on flashing.
you will probably se the light flashes 7 times then pause and then repeats.this indicates that your unit did not heat the water correctly.
most likely youi dont have enough hot water going into the unit, 120degrees or more, or the latch is not engaging fully. check the temps and then the latch strike. its on the tank and is chrome type metal bracket.
it should be bent down towards the door frame until it just clears the door. if its too high it wont make the door switches work properly and then no heating of the water.
try it.
to get rid of the flashing, push the high temp wash, air dry, high temp wash, air dry. then it will go thru a test cycle and back to normal.
takes about 7-10 minutes.
tom
Dec 31, 2009 | KitchenAid Dishwashers
Hi! I'm having a problem with my dishwasher its a Kitchen Aid Mod # KUDK03CTSS3 It's is just rinsing the dishes then stops completely and the start/resume button flashes!
have you found a solution? i have the same model and it won't take the detergent and only rinses the dishes. please let me know! thanks.
Sep 26, 2009 | KitchenAid Dishwashers
Which dishwashere auto resume wash cycle when door is closed?
All the tall tub dishwashers made by Whirlpool (inc. Kenmore and Kithcenaid) must have the start button pressed after adding a dish. If the start button control light is blinking, you must press start. On those models with buttons on the top of the door you must, in addition, close the door within aprox 5 seconds after pushing start. Hope this helps. Ken
May 01, 2009 | KitchenAid Dishwashers
Mar 03, 2007 | Kenmore 24 in. 16009 Built-in Dishwasher
Dishwashers Logo
266 people viewed this question
Top KitchenAid Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Marvin
Marvin
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
