Question about Mtd Garden
My MTD lawn tractor ,mod.no. 136m673g131 will not turn to the right.. How do I repair??
Posted by Ron Rylatt on
5 Related Answers
Dwain Pippen
  • 376 Answers
SOURCE: how to remove rear wheel of lawn tractor
You should be able to remove the bolt from the center with a 1/2" socket an slide it off the axle. You do not want to do any heavy hammering on the wheel because you could possibly drive the axle out of the transmission. MTD mowers are notorious for being hard to get the rear wheels off. If you do get them off or ever buy a new one, remove the rear wheels and coat the axles with anti-seize compound. Good luck
Posted on May 15, 2009
Anonymous
SOURCE: MTD Lawn Tractor: Constantly shredding deck belt...
I have the exact same model MTD tractor with same problem. It began when the bolt that extends through the idler arm assembly broke and subsequently damaged the pulley. Upon examination of the broken bolt, I found that the threaded end that extends below the deck is significantly smaller that the rest of the bolt. I got a larger bolt with the same size threads, bored out the hole through the deck and it made the whole idler assembly much stronger. the deck still has some vibration and some unusual belt harmonics, but it appears to be working. Compared to most other tractors of this size, this deck is very complicated.
Posted on Jun 15, 2009
Anonymous
  • 41 Answers
SOURCE: yard man mtd 20hp 46
go to the online web site for the yardman this will give you the guide on how to replace the belt.
Posted on Jul 12, 2009
Anonymous
  • 226 Answers
SOURCE: MTD lawn tractor. 16 hp twin briggs straton
THIS SOUNDS LIKE A THROTTLE CABLE LINKAGE PROBLEM.WITH THE HOOD OPEN AND MOTOR RUNNING RUN YOUR THOTTLE UP AND DOWN WHILE LOOKING @ THE LEFT SIDE OF THE MOTOR TO SEE IF THE CABLE IS FROZEN IN PLACE OR BROKE OR DISCONNECTED .HOPE THIS HELPS
Posted on Jul 16, 2009
bd_dale
  • 12 Answers
SOURCE: Lawn tractor jerks when driving across lawn
Can you adjust tensioner
Posted on Jul 20, 2009
I have a 2010 MTD series 760-770 lawn tractor. When starting, just getting clicks under the seat. Is there a solenoid to replace? No mention of one in the owners manual replacement parts list.
Diagnose & Troubleshoot - MTD Products
www.mtdproducts.com > Home > Owner's Center
MTD ProductsYou can use the Part Finder to help find your model and the right part for your machine.... Select your machine type below to start troubleshooting. We'll provide you with symptoms of common lawn mower problems to help you diagnose your .
Sep 14, 2015 | Mtd Garden
MTD Lawn Tractor: Flywheel hard to turn in one spot.
sounds like rust build up on the magnet flywheel remove the cover from the top of the engine and clean it
Aug 09, 2012 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
Need to repair manual for 1998 MTD lawn tractor drive springs
Since everything is online, do a Google search for a manual, also try ebay, if no luck try MTD
Jul 04, 2011 | Mtd Garden
My MTD 14hp lawn tractor (38", 6 speed) shuts of
You have a short somewhere . A cut or stripped wire that , at the time of lowering your deck, touches the body. It's like turning off your key. Look around under your deck and you will find what I'm talking about. Fix wire and tie up to prevent future problems. GOOD LUCK.
Jun 16, 2011 | Yard Machines MTD Gold 20 HP Lawn Tractor...
Need spindle assemblies for a 2000 vintage, 600 series, 42 deck. and belts
Go to partstree.com and enter the info it asks for IE: Mtd mod #13aj771s004 then follow what it asks for.
its worth a try
Apr 30, 2011 | Yard Machines MTD Gold 185 HP Lawn Tractor...
I HAVE A 1994 MTD 18HP BRIGGS WITH MOD #144Q828H118, WHILE I WAS MOWING THE CLUTCH WOULD NOT RELEASE AND THE GEAR SHIFT WILL NOT GO INTO THE LOWER GEARS. WHAT HAPPENED?
The tractor has a variable speed pulley for the 1-6 gears. You will want to check the top pulley on the shaft that is in the center of your tractor between the engine and transaxle. you may have broke the spring or adjuster.
Apr 24, 2011 | Yard Machines MTD Gold 185 HP Lawn Tractor...
Nooo parts
Find a local MTD dealer, lawn mower repair shop, they should be able to get you one. The Cub Cadet is made by MTD.
Sep 15, 2009 | Cub Cadet Street Sign- tractor lawn riding...
My deck cuts shoter on the rt,ie uneven
Check your tire pressures:
10 psi. for rear tires.
14 psi. for the front.
Note that according to MTD:
Making sharp right hand turns. Twin-blade mower decks are designed with the discharge on the right side and two side-by-side blades. The side-by-side twin blade decks have the left hand blade positioned slightly forward and in front of the right blade. This provides cutting overlap when traveling in a straight line. As a result, the tractor should mainly operated making primarily left hand turns when cutting. During left turns this cutting overlap is maintained. If turning right when, it is possible to negate this overlap and leave an uncut strip.
May 31, 2009 | Mtd LAWN MOWER PART # 683-0439A DECK...
Garden Logo
44 people viewed this question
Top Mtd Garden Experts
Dennis Key
Dennis Key
dannydoesita
Marvin
Marvin
Are you a Mtd Garden Expert? Answer questions, earn points and help others
